Question about HP LaserJet M1005 Printer
Error bo605 hp laser jet m1005 - HP LaserJet M1005 Printer
md_ehsan_1
  • 255 Answers
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Posted on Jul 04, 2009
  • 75 Answers
SOURCE: HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Posted on Nov 04, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
SOURCE: How do i refill my HP M1005 MFP Laser Printer toner cartridge?
if any softwere is have you for chaquing my cartage how many days are left to changing thel me
Posted on Oct 28, 2010
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
In my laser jet M1005 printer showing the scanner error 12
It could be dusty in the cis unit or scanner unit as its called.you will need to remove the glass and clean the scanner
Oct 29, 2012 | HP LaserJet M1005 Printer
Hp laser jet m1005 scanner error 20 cud u tell me what is the problem
Open flat bed glass, remove scan head(which part is moving right & left having light)check driving mechanism any breakage/warn out replace mechanism if its good replace scan head..see the snapshot idle scan head mechanism breakage areas for observation.
Oct 06, 2011 | HP LaserJet M1005 Printer
Hp laser jet m1005 mfp scanner error 12 problem print ok
hi
1. check for driver update
if not resolv
2. Firmware Update
if not
3. the motor of the scaner is damage
May 30, 2011 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
Scanner error 12
Jul 04, 2009 | HP LaserJet M1005 Printer
HP LaserJet M1005 Printer Logo
Seeker5211
Seeker5211
