Question about Samsung C5212 Cell Phone
Samsung 5212 key board not working
Inner key board alread replaced also not working
5212 keys not workding
What main line 789 keypad
Feb 12, 2014 | Samsung C5212 Cell Phone
Problem with Mitel 5212 IP Phone
Need to login to. The phone system and change it back.
Jun 06, 2013 | Mitel 5212 IP Phone
Network parameters of 5212
Reboot phone and hold down the down arrow key this will bring you to the config of the phone
Mar 05, 2012 | Mitel 5212 IP Phone
Keypad not work
Best the thing to do is to change new key and update the phone.
I hope this will work for you.
Sep 11, 2011 | Samsung C5212 Cell Phone
How is the light in the keyboard activated?
*******You switch it on from the BIOS set up******
Start the computer
Press delete key to go to "SET UP"
Select advanceD BIOS features
Look for "BOOT UP NUM-LOCK" and set it to ON
Save settings and restart your computer
****Some times its alread switched on by the manufacturer on the mother board*******
Jul 06, 2011 | Computers & Internet
Cannot get incoming calls on my Mitel 5212 IP phone. When my colleagues phone internally, they get the "NO DISTB" message.
Your phone is in Do-Not-Disturb. Press the blue superkey. Press No until you see DND or Do-Not Disturb and press yes... press Turn off.
on this phone, the * and # are the keys for yes and no.
Nov 11, 2010 | Mitel 5212 IP Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
Two lights on phone mitel 5212 ip phone
It sounds like your phone is in do-not-disturb. Press the blue key. Press the no (# key) until you see DND, then press Yes (* key). Press Turn off (0 key).
Apr 07, 2010 | Mitel 5212 IP Phone
Problem for Samsung TXN2798HF 27" TV Shuts off by itself after about 15 minutes. Sometimes longer sometimes shorter. Don't know much about the inner working of a television but I am pretty handy at fixing...
the power supply board is failing and needs replacing.replacing board is the easiest thing to do, lay tv down on a soft blanket(screen down), remove back cover and you will see the board. 4 screws and a couple of connectors and it is done. call 1-800-samsung to find the closest service/parts center to order board.
Nov 18, 2009 | Samsung TXN2798HF 27" TV
No sound or picture HL-R5067w samsung
See my TIP on my page and see if that helps u. Also the lamp could be toasted. Let me know, i may have one in stock. Thank you GURU JAY
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung C5212 Cell Phone Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
