Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub hdd no hdd found
  • Konica Minolta Master
  • 6,161 Answers
What about it machine may not have one
Posted on Mar 11, 2017
Can i scan without hard disk
Enter in service mode set HDD formatting HDD and set Install HDD.
Jul 23, 2014 | Konica Minolta Bizhub c203 Copier
Receiving error code C-E301
I just found this on the knowledge base it refers to this code when the hdd is replaced and internal data is different it may be a faulty hdd but there is a firmware in reference to this code.
Error C-E301 occurs for mismatching in the internal data as HDD is changed.
C-ED01 will be displayed as the mismatch in the internal data occurs as HDD is changed.
HDD Format will be necessary when this trouble is displayed.
firmware: A2X00Y0-F000-GPQ-65.exe
Mar 31, 2014 | Konica Minolta Bizhub C454 Color Copier
Bizhub c253
will require install kit do you have that and the hard drive kit to seperate kits
Feb 12, 2014 | Konica Minolta bizhub C351 All-In-One...
Procedure For Installation Of Hard Disk In Bizhub 363
Procedure for Installation of Hard Disk in Konica Minolta bizhub 283/363/423 Photocopier Machines,
1-Get a SATA hard disk. NOTE: SATA HDD is supported in the above mentioned models. IDE or PATA are not supported.So get a SATA HDD.
SATA HDD have two main connectors. 1 is for Data and the other one is for power as shown in the image.Two separate cables are used.Data cable and the power cable.Get both the cables.Image of the cable is shown below.
bffe98cc-9b42-4878-b7d2-80a65e264546.jpgData Cable for SATA
107b626c-ac31-4927-b142-6dd8674309f2.pngPower cable for SATA Hard Disk
3-Connect the cables in their respective areas.
4-Now place the hard disk on its fitting. HDD mounting kit is fitted at the main control board of the machine.For this, open the back side cover of the machine and you will get the fitting.It will be on the main board in front of you. Now fit the HDD on its mounting and tight the four screws at its sides to keep HDD safe from shocks / jerks.
5-Now connect the data connector and the power connector to the control board.There will be two separate jacks for power connector and the data connector.
6-After fixing both the connectors to the main board, close the rear cover of machine with the screws.
7- Now turn the machine ON.
8-Go to the service mode and click on "SYSTEM 2"
9-Now click on "HDD" and select "ENABLE" and press "OK"
10-Now click on "state confirmation"
11-Select "HDD"
12-Now click on Format Hard disk.Select "Logical Format" not the physical format.Press "START" button and wait for few minutes.
13-When formatting is finished press "OK" and restart the machine.
14-Your new HDD installation is complete now and its ready to use for box operations.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
HDD install guide for bizhub 250
do you have the expanded memory kit and mounting brackets or do you already have the Fax and scanner kit installed?
Apr 03, 2013 | Minolta bizhub 250 Black and White Copier
Bizhub c450 scans multiple pages to separate scans
hi im lorenzo and i have been fixing konica minolta machines for about 2 years well lets catch to the case.
If you still have problems or cant change to multiple scan.
1.you have to get in the simulation mode because machine doesnt know if the HDD installed is in.
*simulation utilty/counter =details stop 00 stop 01
2. ONCE YOUR IN LOOK FOR SYSTEM 2 AND CLICK ON HDD YOUL SEE THAT HDD IS NOT INTALLED SO CLICK INSTALLED AND THEN EXIT END AND REBOOT THE PRINTER AND TRY TO SCAN AND IT WILL WORK
THUMBS UP IF IT WORK FOR YOU
Jul 18, 2012 | Konica Minolta bizhub C250 All-In-One...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Hard drive on Bizhub 350
you have to order it form KM service, because, there is also special cabel and metal plate to install hdd, and installation instruction is included.
good luck
Apr 14, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
