Question about HP LaserJet M1005 Printer
Hp laserjet m1005 error bo605 - HP LaserJet M1005 Printer
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
  • 10 Answers
SOURCE: scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Posted on Jun 23, 2009
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
  • 72 Answers
SOURCE: scanner error 12 on hp
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Posted on Apr 22, 2011
  • 140 Answers
SOURCE: driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
Posted on Apr 25, 2011
How to solution scanner error 17 in hp m1005
HP LaserJet M1005 Mfp driver pls check the scaner lamp is moving or not i f not pls replace the scanner cable
Jan 09, 2017 | HP LaserJet M1005 Printer
Hp laserjet m1005 scaner error 20
Scan head drive mechanism faulty., Follow the snaps chk for breakages.,
Replace new part if its available, If not alter the part as shown in snaps..( ex:which I did early)
Feb 26, 2015 | HP LaserJet M1005 Printer
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
Hp laserjet m1005 initializing problem
The wizard did not successfully complete copying your picture because an error occurred.
See details error information. The following problem occurred while copying picture: Unspecified error
Oct 31, 2013 | HP LaserJet M1005 All-In-One Printer
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Scanner error 12 on hp laserjet m1005
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
Scanner error 20
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
HP LaserJet M1005 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
