Question about LG LFC25776 (25 cu ft) Bottom Freezer French Door Refrigerator
Lg lfc21776 not freezing - LG LFC25776 (25 cu ft) Bottom Freezer French Door Refrigerator
I have a lg g pad 7.0 and it keeps freezing on me how do i get it to stop freezing up?
Sounds like a software issue. If possible see if there is a update for the device. That could help with the freezing problem.
Dec 02, 2014 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
My blue ray player LG BP620 keeps freezing
Same problem here. BP620 freezes up randomly. I have to unplag and wait. Then it freezes up again as the film progresses. I did a factory rollback and disabled wifi. Things are working much better. Very Strange ! I will call LG tomorrow and will return this BlueRay player if they don't have a fix on this problem.
Jan 01, 2013 | LG Televison & Video
When i turn on my LG gt400 freezes on homescreen
When i turn on my LG GT400 It freezes
Jun 03, 2011 | LG Cell Phones
Lg gw300 keeps freezing and crashing on me phone is only 3months old
Hi to solve this you have to contact lg service center and tel them about this they will help you
May 11, 2010 | Cell Phones
Picture freezes
Contact your LG dealer for a service engineer, the software version currently in the TV may need updating, there is an update available for picture freeze problems.
Jan 08, 2010 | LG 42LG30 42 in. LCD HDTV
I have a LG PC1DV Plazma and every now and then the picture will freeze, the sound continues on and you cannot change channels. the only way to un freeze is to turn off tv wait 30 sec then turn back on and...
Contact your LG dealer & have someone call to check the software version currently used by the TV. It may need updated as there is an issue for picture freeze, if this is ok there could be a problem with the signal strength of your signal, if this drops then it will also cause the picture to freeze, in which case you would need to have your aerial checked.
Dec 21, 2009 | LG Televison & Video
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Vx5300 Freezes
Here is the cure:
http://slashdown.wordpress.com/2008/02/05/fixing-lg-vx5300-freezing-problem/
Jan 07, 2008 | LG VX5300 Cellular Phone
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
LG LFC25776 (25 cu ft) Bottom Freezer French Door Refrigerator Logo
27 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
