Question about AT&T 1740 Digital Answering System
Blinking number in message windw wont clear
Blinking number in message wont delete
Says mailbox full and wont take messages
Answering systems are limited in size, typically to about 12 minutes of recording time. When full, no more messages can be taken: you will have to delete some (or all) old messages to clear room for new ones. Follow the instructions for your phone to delete messages, if you need the manual try www.manualslib.com and enter the model number of your phone (usually on a small sticker under the base or in the handset under the battery). Good luck!
Apr 11, 2016 | Lands Phones
Blinking light voice mail ms9 via phone co wont turn off
The blinking light usually means one of two things: 1) message box is full or 2) you have a new message. Deleting messages should solve this problem for you. After you delete the messages, if you still have a blinking light, unplug the power cord and take the batteries out of all the phones linked to the base unit. Then one at a time put the batteries back in after you plug the base unit in. This should clear and error. Some base units have a back-up battery, don't forget to remove it too!
Apr 14, 2015 | Lands Phones
The new message light keeps blinking and how do i delete or listen to messages
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
Jul 27, 2011 | RCA 25413RE3 Corded Phone
HOW DO YOU CLEAR RECENT CALL AND MESSAGES
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
Success.
May 09, 2011 | Motorola Cell Phones
Voicemail light flashing but no message
This can usually be fixed by calling the phone number that the voice mail indicator light is flashing on from a different phone number. Leave a voice mail message and then go into the voice mail and delete the message that you just left. The indicator light should then go out.
Sep 14, 2010 | Mitel 5212 IP Phone
I want to clear deleted messages because my
go to your message click and hold on tol the name/number and its going to say delete thread and it would delete all the text that you and that person talked about or if you dont want to delete the whole thing go to message click on the name/nuber and look for the message you would like to delete and click and on hold the message and you are going to see options and you are going to see delete message and it would not be there anymore.
Nov 11, 2009 | HTC G1
Deleting the recent log
thank u so much for trying to help. I guess my message wasnt clear enough though. The phone is not storing my "messages", I'm not having a problem with that, I can clear them, no problem. Its the "recent log" under the "add recipients" that does not clear. The "recent log" stores all the numbers you ever text messaged to. I want to clear the #'s that I've text messaged to, not regular calls, thats easy to clear. For some reason this phone stores all the #'s that you text to. If you can figure it out, i'll give u a million dollars!!! just joking of course.
thank u!
Jan 24, 2008 | Samsung SYNC SGH-A707 Cellular Phone
AT&T 1740 Digital Answering System Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
