Kelvinator kl600 washer door won't open - Washing Machines
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Posted on Jun 11, 2012
SOURCE: my washer maytag MAH5500BWW A2982915CE door won't open,
TRY UNPLUGGING IT
Posted on Dec 02, 2012
Why is gas leaking from my kelvinator fridge
probably a hole in the evaporator
But I have to ask what is it you are seeing as the gas is not visible to the eye
is it a mist that you see on opening the door or has the compressor stopped working
Aug 22, 2015 | Kelvinator Refrigerators
How to open the door of a kelvinator kl75cm washmachine
Try unplugging the unit for 30min. Sometimes this will reset the washer. My washer also has directions in the owners manual how to open when this happens.
Apr 12, 2014 | Washing Machines
May tag washer Neptune door won't open
what is your model number is then we can get started then
Oct 25, 2012 | Maytag Clothes Washer Dispenser Bezel...
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Electrolux washer door won't open
Hi.
Jun 11, 2012 | Electrolux Washing Machines
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
