Question about Samsung CLP-365W Color Laser Printer
Replace or install waste toner container - Samsung CLP-365W Color Laser Printer
Keeter
  • 41 Answers
SOURCE: Waste Toner Full/ Not Install
Behind the little container for the waste toner there is a sensor that senses whether the toner basket is full or not. If the sensor itself is dirty, it can give a false reading. First try cleaning out the area under the container to see if the switch works. Also make sure the container is clean, because the sensor works by sight, so if it looks full because it's dirty, it will give a false reading. I have heard of people disabling that sensor in various ways, but that can get dangerous to the printer. I can't recall the details on that exact model, but I believe there is a diagnostic of some sort that can test that sensor to make sure it works right to begin with.
Posted on Sep 20, 2006
  • 279 Answers
SOURCE: waste toner tank
A few things can cause this.
The way the printer determines whether the waste tank is full is via 2 optical sensors, one on either side of the tank. You'll see a rounded bulge on one end of the tank - the sensors are on either side of that, when the tank is installed. Under normal operation, light passes through that and the printer reads it as meaning the tank is not full, until the tank fills far enough to fill that bulge, and thus block light and give a tank full reading.
If the tank gets too dirty, not enough light passes through and it gives false tank full readings. So the first thing to try is cleaning the tank with soap and water. Make sure that area is as clear as possible.
If that doesn't work, it has also been reported that the sensors themselves are unreliable. I am told Samsung will replace the sensor for free if it's been less than 3 years. If you call them, insist that it is the sensor that is the problem, or they will try to get you to replace the waste bin, at your expense, first: 1-800-726-7864.
Alternatively, you can remove the sensor from one side, and reattach it to the other side - putting the two sensors in contact so that they always read an empty waste tank. Do this at your own risk, however, as you will have to check the tank regularly and make sure it doesn't overflow. Doing this bypasses the sensor, so there is no longer any warning if your tank is overflowing.
Hope some of that helps you.
-Dyllan
Posted on Jan 14, 2008
waqar697
  • 67 Answers
SOURCE: What does waste toner contain?
put the trash in a plastic wrap it then throw it into trashbin
Posted on Apr 01, 2009
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
Posted on Jun 15, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Feb 07, 2011 | Sharp MX-2300N Color Copier
When I go to print it starts beeping and telling me to check waste toner box?
The waste toner box is located on the right hand side of the printer. There is a door/cover that opens up on the right side. It is a milky white plastic container. Check to make sure it is there and installed properly and the door is fully closed. If all that is correct it my be full.
There should be a new waste toner container in the toner box (along with a toner). The toner and waste toner are normally replaced at the same time.
If you don't have a new waste toner container you can tray emptying the one that is in the printer BUT be very careful. The toner is a fine powder and can get all over if spilled. If you ever spill toner never use water or any other liquid to try and clean it, that will just turn it to a liquid ink.Brush it off your cloths and vacuum it up.
If you do try and empty the container and the machine continues to tell you it needs to be replaced it can be because there is still toner on the inside of the toner container and the sensor is seeing it there.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Mita FS-3820N Laser Printer
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
7 Close the front cover firmly.
8 Turn the machine on.
Caution
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Xerox Office Equipment & Supplies
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
1 Turn the machine off, then wait a few minutes for the machine to cool.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Replace waste toner container message
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLP-365W Color Laser Printer Logo
131 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
