Question about Panasonic DP-8016P Copier
Error at display add paper in tary1
Paper lift moter is not working paper is not sensed & massage at display is add paper in tray1
Inside the lift motor housing, a gear fits into a molded piece of the housing. The molded piece is broke.
Posted on Feb 19, 2014
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Printer prints 1 page and gives an empty one after that unexpected paper size
1.Check paper sizes, if its same as what paper you are using..
2. Clean paper path sensors, if these are dusty paper not sensing properly while paper travels, result paper mismatch.
Do this exercise If you are not tech guy: Remove cartridge, lift registration assm plate blow air with vacuum cleaner, as well as tray1 area,tray2 area.. Best of luck..
Sep 04, 2012 | HP LaserJet 5000gn Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
Add paper problem in hp laserjet 3050 all in one
> Remove side & back doors..> See the snap shot, clean these sensors, check sensor flag springs properly in place/dislocated?, shoot the problem, fix it back & try..
Dec 05, 2011 | HP LaserJet 3050 All-In-One Printer
Blue smudge marks are printing on the edge of the paper
These defects normally occur when printing is attempted on unsupported media or when the printer is set up for a different type of media than the media that is actually loaded into the machine.
Check your media and ensure that it is suitable for use in the printer. Refer to the printer's user manual for information on supported media types and weights. Is the media you are printing on supported in the printer?
Ensure that the paper type is set accurately on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type). Is the paper type set correctly on the printer operator panel?
Change the paper weight setting to heavy on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type/Heavy Paper/Check button). Try printing your document again. Did the error return? If the error returns, please contact Lexmark Technical Support for further assistance.
Jul 12, 2011 | Lexmark C532n Color Laser Printer
THE PRINT FROM MY LEXMARK PRINTER IS SMALL AND I CANNOT ADJUST THIS. CAN YOU HELP PLEASE
Your printer supports a wide variety of paper sizes. See Media guidelines for illustrations of proper paper orientation. The printer determines the size paper loaded in the trays by the position of the paper guides. Make sure you adjust the guides each time you change paper sizesYour printer can automatically sense when A4, letter, legal, executive media or B5, DL, and #10 envelopes are loaded in tray1. To do this, the Auto Size Sense setting must be set to On. Your printer default was set at the factory to either the US or Non-US default with the Auto Size Sense setting On.To change the Auto Size Sense setting to Off: 1 Turn the printer off. 2 Press and hold the Go and Stop buttons and turn the printer on. 3 Release both buttons when Performing Self Test appears. 4 Press Menu> or <Menu, until the Tray 1 Auto Size message appears. 5 Press Select. 6 Press Menu> or <Menu, until Off appears on the display. 7 Press Select. To return the Auto Size Sense setting to On, repeat steps 1 through 7 but, select On during step 6.
Sep 03, 2009 | Lexmark P4350 All-In-One InkJet Printer
Out of toner U13 Error Massage display continuous.
are you using the original cartiage,if yes chek the toner moter
Mar 15, 2009 | Panasonic WORKiO DP-8016 Printer
Error Jam0 in tray1
GO ON LINE TYPE IN MANUFACTURE NAME,MODEL#, ERROR MESSAGE AND ENTER KEY LIKE THIS:
CAMSUNG CLP-500 LAZER PRINTER ERROR MESSAGE JAM0
ENTER
ROD
Feb 09, 2009 | Samsung CLP-500 Laser Printer
Dear Sir, We have a Fujixerox Docuprint C2100 and we have a message error about our tray1. We try to print using tray1 (have paper inside) but the printer request paper.
I would remove the tray from the machine and all paper from that tray. Then turn it over and make sure and make sure that the paper slides are working correctly. The machine doesn't actually detect the paper just the fact that you have the paper slides up against it. So after you have put the tray back in the machine make sure the paper slides are firm up against the paper and it should be fine.
Also, while the tray is out of the machine make sure there is nothing in behind the tray blocking the sensors.
Jan 19, 2009 | Xerox Phaser 8500/DN Printer
Paper getting struck and web blade chanve massage
hi im jules_09,have you tried cleaning the fed roller on tray2 and by pass tray?try cleanig it with alcohol just get a cloth a soft one then put alcohol on it then rub it on the roller 360 degrees ok,then if does not work your clucth motor id deffective have it replaced
Dec 01, 2007 | Canon CLC 1180 Copier
Panasonic DP-8016P Copier Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
