Question about Epson Perfection V370 Photo Scanner 4800x9600, USB 2.0, PC/Mac
SOFTWARE EITHER EXPIRED OR HAS DAMAGED/FAULTY ABBYY FINE PRINT.
SCANNER IS FINE, GET TO TO THE END OF SCANNING, AWAITING TO CONVERT TO PDF AND SEND TO MY SCANS FOLDER, SCREEN APPEARS ABBYY FINE PRINT WILL TERMINATE SERVER UNAVAILABLE AND THATS THE END.
2 Suggested Answers
  • 2678 Answers
SOURCE: The scanner is fine and
This is a registry error as thr RPC (Remote Call Procedure) cannot be started.
Microsoft KnowledgeBase article that mentions a Registry key called HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Rpc, but that key may fine on the your machine if you examined it with REGEDIT.
It is more likely the missing reg key is HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RpcSs
Messing about with the registry is not recommended if you are unsure ofr what to do as you can cause more problems, so I would not do that.
Unfortunately you do not say which OS you are using so I will guide you through XP and there will be similarties in Vista and win7
Quickest attempt. Uninstall printer and reinstall. If XP(or any) disconnect printer before reinstalling.
If that fails then I suggest running a CHKDSK from command prompt .
Easy in XP click start/run and type cmd in the box that comes up.
For Vista and 7 you need to do this
Click the ORB and
go to the run box and type in cmd. Now instead of hitting the Enter key, use Ctrl+Shift + Enter. You will be prompted with the obnoxious User Account Control dialog… but it will then open up a command prompt in Administrator mode. Then type in CHKDSK /r note there is a space between the K and the /.
It will tell you the disc is locked and would you like to run CHKDSK on reboot, enter y for yes, enter then type exit.
Reboot PC, this could now take some time as your HDD will be checked and repaired if a problem is found.
Please note there is no guarantee that this will solve the problem but it should.
Let me know how you get on.
Posted on Sep 03, 2010
Problems saving a scanned item as a .pdf file
You will need to re-install Abbyy Finereader software.
Nov 28, 2013 | Epson NX125 AllInOne InkJet Printer
Scanning
convert it to pdf (Adobe Acrobat Professional)...
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
I have Mustek 1248US. Can it scan to PDF?
Scan to PDF is controlled by your software. What OS and software are you running? Under Windows, Nuance's PaperPort, http://www.nuance.com (or OmniPage which includes PaperPort) or Abby Fine Reader Express, http://www.Abby.com , both will let you scan to PDF. Open the software and set the options for scanning to PDF. Then press the scan button in the software. (Depending on the OS and Mustek driver, you may get this to work by pressing the Scan button on the scanner itself. This depends on installing a monitoring program that may be included in the drivers. This "listens" for the button press and then launches the desired software.) Other third-party software may also do this.
If you are using something like Windows Fax and Scan, you'll have to do two steps. Scan and then convert the file from an image to PDF. (There are dedicated programs that convert image files to PDF or you can do this is Microsoft Office or other office suites with the appropriate add-on.)
I hope this helps.
(I have an older scanner with Windows 7; I can only scan to PDF with third-party software.)
Mar 14, 2012 | Mustek Scan Express 1248UB Flatbed Scanner
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
I have been asked to do some research to find some of the best programs to convert a PDF to a Word document. Any suggestions?
Try the following:
ABBYY PDF Transformer - much "light-weighted", resource-consumptive and easy to use application, which is specially intended for PDFs
ABBYY FineReader 9.0 for general work (it's simply the Best!), Able2Extract for locked PDFs.
Thank you.
Jul 31, 2010 | Online Double Conversion 1500VA 1050 Watt...
Scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
May 24, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How do I scan a document and save it to my PC
have you tried loading the scan program from the my pictures program on the computer
May 26, 2009 | HP LaserJet 3020 All-In-One Printer
Bar Code Used as Document Name
It's not really an issue with the scanner. The scanner will pick up the image and convert it to whatever you want, but your backend software is what you'll need to mess with for this. Any form recognition software will work (Form Storm, ABBYY FormReader, etc.)
Dec 27, 2007 | Canon DR-7580
Epson Perfection V370 Photo Scanner 4800x9600, USB 2.0, PC/Mac Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
