Overheating they say head gasket changed
If you have white smoke from the tailpipe, coolant in the engine oil, engine oil in the cooling system, that indicates a head gasket failure. However, the most definitive way to test is to have a hydrocarbon test done on the cooling system (checks for exhaust gasses that obviously don't belong in there).
If the system comes up clean, you still can have either a leaking intake gasket, partially obstructed radiator (many times flush will go around obstructions not through them), a malfunctioning electric fan or fan relay, or even an obstruction in front of the a/c condenser or between the condenser and radiator (leaves, plastic bags etc) Don't forget though even if the cause is other than a gasket, if repeatedly or severely overheated the head gaskets can also fail. That is why complete testing is very important.
good luck
