Question about Sony Walkman WM-FX242ST Personal Cassette Player
I want rubber for sony m455 - Sony Walkman WM-FX242ST Personal Cassette Player
Shadow copy
Need a little more info but if you are using a laserjet printer shadows or duplicate images usually come from worn out rollers in your fuser. Depending on your model fusers are available by themselves or as part of a maintenance kit. Replace the fuser and that should take care of the problem.
Nov 02, 2013 | Sharp Toner Digital Copiers Ar M355 M351...
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
Hi there I am getting code c31-23 can you please
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jul 28, 2010 | Sony Handycam DCR-TRV140E Digital...
Sony Rolly Rubber Wheel Lost
Hi.
I have the same problem, my kid just lost a black "rubber feet" from a black rolly, did you ever got one, if so where can i buy it?, else would you consider selling the one you have left?
Thanks, have a nice day.
chupepe at gmail dot com
Jan 17, 2010 | Sony Rolly SEP-30BTWHI MP3 Player
I have a sony dcr v240. A black rubber roller
well this has been sitting for some time now. but the solution would be wd40! well the straw off of it really, put your roller on and then cut a peice the straw sometimes a can of air staw works to and carefully slide it on.
Jan 15, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Error C:31:23 on Sony trv27
Jun 12, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Mar 10, 2008 | Audio Players & Recorders
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
Sony Walkman WM-FX242ST Personal Cassette Player Logo
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
