Question about Itech i.Tech i.Oval 303 Bluetooth Headset
What is the pairing code?
I am failing to pair with my phone
The pairing code is a sort of a password that only the primary sender will have on their devise and this code in turn reflects unto the secondary receiver. Failure to insert this code within few seconds the devise will fail pairing and you have to start over again, switching bT on and off again.
Feb 12, 2014 | Itech i.Tech i.Oval 303 Bluetooth Headset
Em227 wont pair with samsung intensity... phone will recognize but continually get failed pairing message... please help!
make sure that the code you enter in to the phone as the pairing code is correct. most of them are 0000 or 00000, some of the samsungs are 1234.
this code must be entered in correctly to pair the device. If you are using an iphone, there are some issues with it people report.
Aug 24, 2011 | Southern Telecom Emerson Bluetooth Headset...
I have tried pairing my second phone which is a verizon lg vx9200 and it keeps telling me pairing failed. I have entered passcode 0000 and it keeps telling me pairing failed. any sugestions
some bluetooth products will only pair with one thing at a time. if you are actually swapping for another phone it may help to delete the original paired phone...hope this helps
Oct 09, 2010 | Blueant Supertooth 3
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
When I try to pair my Nokia N97 mini to my 3200 LS parrot it wont pair. My phone sees the parrot but then then says pairing failed and does not give me the opportunity to enter the pin code. Any thoughts?
firstly you need to go to settings / paired devices & delete any old pairings, the go to settings / pair with phone and it will give you a code to enter. Now search for bluetooth devices on your phone and enter the code when prompted.
Good luck.
Nov 15, 2009 | Car Audio & Video
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Pairing my h350
Did you use 0000 as your pairng code?
Dec 16, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Itech i.Tech i.Oval 303 Bluetooth Headset  Logo
20 people viewed this question
Top Itech Radio Communications Experts
My Bible
Level 1 Expert
Tom Chichester
wwlvictoria
wwlvictoria
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
