Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Kenmore proclean gear driven upright leaves a fine line of dust and hair when pushed forward on every stroke
Fine line of dust and hair left by beater bar on forward stroke
  • Kenmore Master
  • 1,284 Answers
First check to see if there is hair and dust on the beater bar and clean it if necessary.
Posted on Mar 03, 2014
reddevil6
  • 1673 Answers
SOURCE: Beater bar works intermittently
When you push the hose into the tube, there is an acuator that will push the switch so the beater bar will turn. That switch could be just dirty, dust gets in them and they won't always work, the acuator may need to be replaced. Either that or you have a bad wire connection somewhere in the noozle or where the wires just go into the noozle asm.
Posted on Apr 15, 2008
  • 172 Answers
SOURCE: beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Posted on Mar 02, 2009
dragonsthatk
  • 547 Answers
SOURCE: beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
  • 9 Answers
SOURCE: Kenmore 34723 Grab-N-Go Upright cannot re-attach dust cannister
make sure the top of the dust cup is properly installed and for kenmore parts go to www.searspartsdirect.com and inter the modle #
Posted on May 22, 2009
shawnphillip
SOURCE: Lever & belt placement in Kenmore Progressive upright vacuum
You are correct. The belt is supposed to go around the peg that is connected to the lever so that when it is on the Floor /Tools setting the belt is not driven by the drive shaft.
Posted on Dec 17, 2009
Testimonial: "This was very helpful - thank you very much!!!"
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
I inherited this vacuum from my mother but I don't have the manual. I have 2 belts for it, but I don't know where they go. I can turn it on and it seems to work, but the bag doesn't fill up...
Most vacuum uses one belt at a time. The belt connects the agitator (beater bar) to the roller which is driven by the motor of the vacuum in the base of the upright vacuum.
To check if the belt is present/intact on the vacuum, look at the sides of the base for two latches. Push the latches away from each other then lift up to remove the cover so that you can check or replace the belt. To replace the belt, lift the agitator out of the base (first lift the right side). Cut off the old belt with scissors if it is still intact before pulling on the agitator. You may need to pull the bumper forward to get the beater bar out of the base. To put on the new belt, slide it onto the roller of the motor then onto the pulley of the agitator. Replace the beater bar in the housing. Start with the left end cap and make sure to keep the arrow pointing down on both sides of the part. Make sure that the agitator turns and center the belt before reattaching the cover.
While you have cover off, check for anything wrapped around the agitator. Remove anything that prevents the beater bar from turning freely. Make sure the area around the agitator is clear of any clogs.
However, if the belt is missing, the volume of dirt picked up will be less but not zero. It is more likely that the unit is clogged. There are several filters that need regular cleaning or replacement. The motor filter is at the bottom of the vacuum bag cavity. It should be cleaned with warm soapy water then rinsed completely. Squeeze out the excess water and then let it air dry. Wait until it is dry before reassembling the vacuum.
An exhaust filter also needs regular cleaning. This is behind the dust cover near the bottom of the area covered by the cover. To remove the dust cover, pull forward and then lay it down. To clean, put the filter under cold running water. Then air dry completely before reassembling the vacuum cleaner.
Finally check if the hose is clogged. First remove the hose by grasping it near the base and twisting it as you pull it away from the vacuum. Pull the hose completely straight then plug in and turn on your vacuum. Stretch out the hose and then let it relax into its storage configuration. Turn off the vacuum and then unplug it. Check for and remove any clumps of dirt stuck in the hose before replacing the hose.
If you have cleaned the vacuum and it is still not picking up dirt, try a different pile height setting on the vacuum. Also check if the agitator should be replaced.
Manage My Life has the manual for the vacuum here: http://www.managemylife.com/mmh/owner_manuals/15123/KENMORE-Vacuum-Upright-L0807740?brand_name_search=33078 . This manual gives the pictures of the various parts that need to be cleaned or replaced regularly. Sears Parts Direct has some parts for the unit; see http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/Model-72136078600/0582/0645000?sid=PDVertical .
I hope this helps.
Aug 03, 2011 | Kenmore 33078 Bagged Upright Vacuum
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
Dec 05, 2009 | Kenmore Vacuums
The beater bar moves when I push the vaccum forward but it just drags when I pull it back, but when I flip it over to have a look it easily turns both ways. How do I fix this?
The belt is stretched that is why it is doing that. You need to replace the belt. Here is a link to the belt you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
Left side of Hoover Windtunnel won't pick up dirt and hair
Take it to your local vac shop for repair. They can help you. It needs to be serviced annually anyway to perform properly.
Aug 07, 2017 | Hoover U5753-900 WindTunnel Bagless...
I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
DC07 works with the hose - but not when upright
Check the actual brush bar is moving. If it is then there's definately a clog and it could well be behind the beater bar. If you can remove the sole plate (which is the grid in front of the beater bar) then undo it and check dirt behind the beater bar, belt and main dust channel. Also check the main inspection air ways and if the beater bar is clogged with hair, clean it off.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Apr 13, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
