Question about Belkin (F1U201) 2-Port USB Switch
Windows does not recognize my Belkin F1U201 2-port USB switch for either computer. Says it has malfunctioned.
Downloaded the most recent driver from Belkin to both Windows XP computers and I get the same message: USB device has malfunctioned and Windows does not recognize it. This device has worked in the past without issue on Wondows 2000 Pro computers. Belkin offers the driver for XP.
  • 31 Answers
SOURCE: Belkin Parallel AutoSwitch F1U115E
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of 255.255.255.0 and the ip address of the gateway. Please respond with any further.
Posted on Jun 06, 2007
  • 26 Answers
SOURCE: Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Posted on Mar 12, 2008
  • 122 Answers
SOURCE: Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Posted on Sep 03, 2009
SOURCE: everytime i turn my computer
The problem is from the belkin usb port software, the belkin usb port software you installed on your system is corrupt and will need to be reinstalled, the previous downloaded or copy of the CD you installed the software from is corrupt, uninstall the belkin usb port software and get another copy of the software to reinstall on your system, with this, the problem will be fix and doing that will solve the problem.
Take care.
Posted on Sep 22, 2010
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
I have lg ms690 mobile device. When I attach the usb to my laptop, I get the message - one of your USB devices is malfunctioned and windows does not recognize it. I downloaded an updated version and still...
Ok I experienced this problem before..try to plugged your phone to the other usb port of your laptop try it at the back the power of the usb port there is sufficient to make your device to function properly..I tell you this because some of the usb port except from the back of a pc CPU gives insufficient power to a usb device that can make the usb that was plugged in it not work properly and not recognized by windows.
Jul 04, 2011 | Computers & Internet
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
Usb not recognized , malfunctioned.
you need to reinstall printer driver .
"USB NOT RECOGNIZED" error come when windows cant to find driver of a new device .
Apr 27, 2009 | Office Equipment & Supplies
Tried the solution you offered for c240....
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
USB device not recognized
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
Jan 17, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Belkin (F1U201) 2-Port USB Switch Logo
47 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
