Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Blank copies on copying and printing blank copies occur with p9 and 21 err codes
  • Konica Minolta Master
  • 6,161 Answers
Sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it
Posted on Jan 22, 2016
  • 3 Answers
SOURCE: Printing Problem
sounds like the fuser is offsetting, i.e old image is sticking to it and being offset onto the next page going through it. I'd look at replacing the fuser first.,
Posted on Oct 29, 2007
firecontrol7
  • 6161 Answers
SOURCE: cof32, blank copy on printing and copying bizhub
Have you open closed the front door to clear code? have you replaced the black image unit? Not the black toner but the image unit Black.
Posted on Apr 25, 2010
  • 170 Answers
SOURCE: The code malfunction has occurred
maybe the thermistor or the thermoswitch or the heaterlamp is the problem just check those parts
Posted on Nov 25, 2010
mmmrwaheed
SOURCE: error code P9 and P21 appears on screen and when
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Posted on Oct 02, 2012
  • 1294 Answers
SOURCE: Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Posted on Jan 30, 2013
Blank copies
you have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt
Feb 12, 2014 | Konica Minolta Bizhub C364 Color Copier /...
Di470 print problem
Might have a problem with transfer/separation assy. directly below the drum. Do copies come out ok? Said when you print is when the problem occurs. Of course the drum could be bad. No codes no maintenance calls like m-1 or M-3
Sep 30, 2013 | Minolta Office Equipment & Supplies
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Removed paper jam and now copies are blank.
Drum Memory
Make about 5 to 10 prints; then, leave the machine in the office environment (normal temperature/humidity conditions)
* This symptom is noticeable in a low temperature/ humidity environment, and is absent under normal environmental conditions.
* This symptom occurs in keeping with the primary charging roller rotation (38 mm).
Sep 13, 2009 | Canon imageCLASS D780 All-In-One Laser...
Canon ir 5570
Replace carona wires or change primary charge unit
Feb 10, 2009 | Canon imageRUNNER 5570 Copier
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
