Question about Enflick TextNow Free - Unlimited Texting and Picture Messaging
Can you have txt now in two devices - Enflick TextNow Free - Unlimited Texting and Picture Messaging
Can I fownload Kindle ebooks on to my samsung tablet?
Yes, you can. But, you have to download the Kindle App to your tablet first. Go to the Play Store and enter Kindle into the search box. It's free. After downloading you can open the app and log on with your Amazon ID and password. Then it will download and synchronize and you will see all the books in your library. All you have to do is touch a book you want to read on your Samsung and it will download forthwith and when the progress bar goes to all the way to the end you can open it and read it. One caution, The Kindle app limits the same book to three devices only.
Mar 22, 2015 | Amazon Kindle D00901 Wireless Ebook 3g...
Sd card password lost
Secure Digital (or SD) memory cards are one of the most popular forms of digital media storage. When using SD cards with a mobile device, you can set a password to protect unauthorized users from viewing the files. However, sometimes, you may lose the SD card password. If you have access to the mobile device, recovering the password is a simple process. If the mobile device is not present, the only way to recover the password is to reformat the device.
Download and install a file explorer application, such as FExplorer, X-plore or Best Fileman onto the mobile device. http://download.cnet.com/f-explorer/3000-2094_4-75758737.html Run the application on the mobile device. Select the "Find" option. Type "MMCSTORE" in the space provided. Connect the mobile device to the computer via either a Bluetooth connection or the connection cable that came with the mobile device. Send the "MMCSTORE" file to the computer. Rename the "MMCSTORE" file "MMCSTORE.txt" on the computer. Open the "MMCSTORE.txt" file on the computer. Write down the password located in the "MMCSTORE.txt" file. b> Using a PC b> Download and install the SD Formatter program from the SD Association website. http://www.sdcard.org/consumers/formatter/ Insert the SD card into the computer's SD card reader. Run the SD Formatter application. Select the SD card from the drop-down menu and click the "Format" button. Formatting the SD card will reset the password. However, the process also will remove any data that is stored on the card. Allow several minutes for the SD card to format. Hope this helps.
b>
Dec 29, 2012 | Computers & Internet
How to open txt file on c7?
use built-in quick office in the device then browse where the .txt file is. or you may download e-book reader that reads .txt format then browse where the .txt file is.
Jun 04, 2011 | Nokia C7 (8 GB) Smartphone
My asus eep pc 701 sd its says reboot and select proper boot device or insert boot media in selected boot device and press a key ive attached a external drive and booted from the disc it stops after 10...
It looks like either the laptop HDD has failed or has become dislodged. Remove the HDD coverplate and ensure the HDD is correctly seated and secure it.
As to the ghosterr.txt problem the biggest cause is a dirty/scratched disc.
Jan 14, 2011 | Computers & Internet
Touch screen on tom tom one is out of alignment toward the top. bottom part of screen is ok.
I found this on the internet, hope it helps....
Touch screen Calibration.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
Feb 23, 2010 | Tomtom ONE GPS Receiver
Texting issues - Motorola Razor V3
I think the issue is with the ROM flashed to your device. Get another ROM into your device. Google will help you for the necessary guidance.
Jun 07, 2017 | Motorola Mobility RAZR V3m Cellular Phone
I need a right driver and brand for my webcam to install
hi please email me and i have the LMC2005 A-D driver for you which i can email to you
Jul 24, 2009 | Logitech QuickCam Communicate STX Personal...
Touch pad seem to be out of calibration - when you touch anywhere on the screen, it highlights about 1/2 inch above where you are pointing - very hard to enter addresses etc.
not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
928 118 107 912
May 19, 2009 | Tomtom ONE GPS Receiver
Have a HP C7280 Photosmart all in one for wireless connection with Belkin 54g Router. Finds router and everything works correctly but when the device is active (switched on) it disrupts attempts to access...
You mentioned it's disrupting internet access when turned on. Can you post the results of a ping and tracert (with it connected via ethernet and turned on)? To ping: 1. Start > Run and type: cmd 2. At the prompt, enter the following and press enter (after each line); cd c:\ ping google.co.uk >> ping.txt ping.txt The last line of the above, will open ping.txt in Notepad, for you to post here. To Tracert: 1. Click Start > Run and type: cmd 2. At the prompt, enter the following (again, press enter after each line) cd c:\ tracert google.co.uk >> tracert.txt tracert.txt The last line of the above, will open ping.txt in Notepad, for you to post here.
May 25, 2008 | Office Equipment & Supplies
Enflick TextNow Free - Unlimited Texting and Picture Messaging Logo
46 people viewed this question
Top Enflick Apps Experts
Nikki  Mclean
Nikki Mclean
Tom Chichester
Veronica
Level 1 Expert
Are you an Enflick App Expert? Answer questions, earn points and help others
