Question about Konica Minolta Office Equipment & Supplies
7272 konica minolta
Sc-1860 still on my machine
  • Konica Minolta Master
  • 6,696 Answers
No 18-60 in the service manual please chk again
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 22, 2016
ayamaya
  • 143 Answers
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Posted on Aug 26, 2008
SOURCE: Konica Minolta Bizhub 920
the copier recognised the paper,but when printing/copying the feeder doesn't pull the paper and on the machine it says paper misfead,open front cover.
Posted on Jan 09, 2009
  • 15 Answers
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
hi, clean the front roller take up ADF with alcohol and the little glass
Posted on Jan 15, 2010
cirocpatel
  • 524 Answers
SOURCE: SC 53-01 Service Error
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di551 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch
turned off, the Service Code will be generated the next time the printer is restarted.
Posted on Apr 29, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta 7272 error codes sc50-5 & 29-4 ....... what can I do......... any solution plz
Mam/Sir,
SC 50-5 is that main drive motor can not turn properly, the second code is that you drum sensor is not reading the drum, For both codes you will need a tech that has some legacy Konica experience might need a a new drum when was last time developer was installed? Might need a new motor or worse case a main control board. Both codes require removal of the drum/developer assembly. Sensor for the drum is under the drum and requires drum removal. Will also need a new cleaning blade which might be the reason the drum can not turn. Developer for the developer section. Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 14, 2016 | Konica Minolta Office Equipment & Supplies
Fix the Error Code Sc 34-02
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Dec 16, 2015 | Konica Minolta 7155/7165/7255/7272/FORCE...
Code sc29-03 in konica minolta 7272
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Konica Printer Support
Dec 20, 2013 | Konica Minolta Office Equipment & Supplies
CODE 02-01 SC23-04
PCL connection area. Mite want to check all connections to the print control board. And Memory sticks, also have the firmware re-flashed.
Feb 08, 2013 | Konica Minolta TN601K Toner for 7155,...
Sc 21-05 for konica minolta 7272
The transfer and separation corona cleaning system locks, lubricate or replace corona unit
Jan 11, 2013 | Konica Minolta Bizhub 7272 Image Control...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Konica minolta 7272 drum unit
Check Charging Unit and Drum Orientation position.
Try to insert by manually rotating Drum.
Jul 16, 2017 | Konica Minolta Office Equipment & Supplies
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
