Question about Gateway Sealed Acer 15.6" Laptop Pc nv57h77u
Gateway NV57H77u cannot change CPU
I have no idea how to remove motherboard to replace CPU on a NV57H77u model, I opened laptop and remove keyboard, but it seems that it has to be completely disassembled to just replace the CPU (for a newer one), any assistance will be greatly appreciated.
    Sergeant:
  • 274 Answers
I could not find any detailed instructions for your laptop. My only tip is to keep track of where you are taking screws from as they will be different sizes and lengths.
Take your time and remove all the screws and if a part will not open, there may be a hidden screw.
Also, upgrading laptop CPUs is not a common practice. If you have never done this, I would not recommend it.
Posted on Feb 14, 2014
Wont start. flashes blue led 5 times
the motherboard will need to be serviced first
Mar 21, 2014 | Gateway Nv57h77u Laptop/notebook
Cannot open Gateway NV57H77u
your laptop has screws in the bottom make sure that you do not lose any take apart then put it back as you had taken it apart
Feb 01, 2014 | Computers & Internet
Nv57h77u
I don't understand your problem. ?
Cant help if you do not explain
Feb 01, 2014 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
Gateway Nv57h77u Laptop service manual
Look for replacement parts on eBay and also have a look at youtube. I find that anything that can be fixed has a video of some sort on youtube. Look for models similar to yours, manufacturers use a lot of common parts and assembly techniques in related products.
Oct 03, 2012 | Gateway Nv57h77u Laptop/notebook
How do i take the keyboard off to see the motherboard on my gateway mx8734
hi willsim , are you mean you have open your gateway laptop to see your motherboard?
you don't want to take off keyboard and all, just turn your laptop in back side you will find sticker and about brand r product name remove it so that u can screw to open your lap top ,in some laptop u can see no of screw visibly, remove it so that u can see *********** board , but its hardly recommended to not open your laptop by yourself , cause if you remove the stickers mean your warranty may be lost. if any more assistance feel free to ask
Dec 30, 2010 | Gateway MX8734 Motherboard - 31PA6MB0090
REPLACE GATEWAY LAP TOP TOUCH PAD
HI THERE!!
Replacing the touchpad of your laptop is not difficult but because laptop parts are very delicate you need to be careful
To remove the touchpad you need to remove the top cover, also known as the palm rest
1.Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
2.Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
3.Slide the battery lock over to the side to pop the battery out from its compartment.
4.Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5.Remove the two screws securing the bezel in place from the back of the laptop
6. Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor
7. Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8. Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9. Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10. Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11.Pull the top cover up from the base of the laptop, removing the touchpad along with it.
NOTE; you can remove your touchpad and swap it out with a new one, but you can also buy a top cover with a touchpad pre-installed.
Jul 08, 2010 | Gateway MT3705 Notebook
How can i remove my laptop keyboard
Hello
These instructions will help you to remove and replace keyboards onvarious laptops. I will not be able to cover all models but you’ll getthe idea. Steps for removing and replacing the keyboard are similar formost laptops.
Warning!
- if your laptop is still covered by the manufacturer’s warranty, do not open the case or you can loose the warranty
- always remove the battery and unplug the AC adapter before you open the laptop case
- if you damage the keyboard connector on the motherboard you’ll have to replace the whole motherboard
- proceed on your own risk
Be careful, on some models the bezel might be connected to themotherboard as it shown on the picture above. If you accidentallypulled the cable, connect it back. It is not necessary to disconnectthe keyboard bezel from the motherboard in order to remove and replacethe keyboard, just put it aside so you can access the keyboard screws.
Use this link below for more instructions.
http://www.laptoprepair101.com/laptop/2007/08/30/removing-replacing-laptop-keyboard/
Regards
PCmania
Sep 26, 2009 | Acer Aspire 6930-6455 Notebook
Replace keyboard on Acer 4720Z
Hi..
I will provide you a solution this solution are very useful with you. You can do it with your self to follow this instructions. There are some image on how to replace the keyboard.
These instructions will help you to remove and replace keyboards on various laptops. I will not be able to cover all models but you’ll get the idea. Steps for removing and replacing the keyboard are similar for most laptops.
Warning!
Sony laptop
I took these pictures from a Sony Vaio PCG-K33 (model PCG-9S1L) notebook. Should be similar for some other Sony notebooks too.
sony-keyboard-1.jpg Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers.
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
sony-keyboard-3.jpg Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case.
sony-keyboard-4.jpg The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
sony-keyboard-5.jpg The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
Toshiba laptop
The following pictures were taken from a Toshiba Satellite A135 laptop. The keyboard removal instructions will be almost the same for most modern Toshiba laptops.
toshiba-keyboard-1.jpg The keyboard bezel removal procedure is similar to the above mentioned Sony Vaio laptop. Lift it up with a small screwdriver and remove using fingers. On most Toshiba laptops the keyboard bezel doesn’t have any circuit board underneath, it’s just a piece of plastic and you don’t have to worry about cables.
toshiba-keyboard-2.jpg After the bezel is removed you get an access to the keyboard screws. Remove two (or more) screws. Release the plastic latch pointed with the red arrow and lift up the keyboard. Carefully put the keyboard aside so you can access the connector underneath the keyboard. Do not forget that the keyboard is still connected to the motherboard.
toshiba-keyboard-3.jpg Before you remove the keyboard, you’ll have to open the connector and release the flat ribbon cable.
toshiba-keyboard-4.jpg Here’s a closeup picture of the keyboard connector on the motherboard. Be careful, this type of connector is fragile. On the left image the connector is closed. On the right image the connector is opened. Unlock the connector by moving the lock up as it shown on the right image and after that release the ribbon cable. Remove and replace the keyboard. For assembly instructions follow all the steps in the reverse order.
Hope it is helpful for you!
Thanks for using Fixya
Regards
ICmanServer
Aug 04, 2009 | Acer Computers & Internet
Replace keyboard Sony
Hi..
Warning!
Sony laptop
Toshiba laptop
Regards
ICmanServer
Aug 02, 2009 | Sony VAIO VGN-BX543B Notebook
Gateway Sealed Acer 15.6" Laptop Pc nv57h77u Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
