Question about GE PSC23SGPSS Side by Side Refrigerator
Freezer and refrigerator stop getting cold
The freezer and refrigerator have randomly stopped cooling down lately. I'll check and the freezer is at 25 degrees or so (even though its still set at 0) and the refrigerator will be at 50 degrees (even though its still set at 37). All the ice will melt all over my floors. I'll hit the Turbo Cool button and seemingly overnight, it will return itself to the set temperatures. This has happened three times in the past month. Is is going through the defrost cycle perhaps, and somehow not cooling back down after?
    Scholar:
  • 101 Answers
Most likely it has a coolant leak or the compressor is bad. I would call GE as there may be a recall to repair this no matter if you are the original purchaser or not. Although with the amount of computerization in home appliances, it could be a main circuit board going bad.
Posted on Feb 12, 2014
3 Suggested Answers
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Posted on Sep 26, 2009
Maytag bottom freezer upper fridge fridge stopped getting cold freezer is fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Refrigerator and freezer both are not cold..they are cool not cold. Freezer doesn't free water or make ice. Stopped working suddenly on Friday, now Monday. Unplugged and it reset itself. Still not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Water is leaking down into the refrigerator from the freezer. How do i get this to stop
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 06, 2010 | Whirlpool Refrigerators
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
My model MFF2557KES refrigerator not getting cold and freezer operating fine.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
The freezer is cooling but the refrigerator is not cooling
OR.
Sep 03, 2009 | Refrigerators
Freezer and frige not that cold
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 06, 2009 | Refrigerators
GE PSC23SGPSS Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
