Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
26PF332026 inch phillips lcd
This tv's turn on but it they show vertical lines down the screens
Re: 26PF332026 inch phillips lcd
Go to this link :
Sorry, it's in French, but there are pictures of the modification to do.
Posted on Mar 22, 2008
0 characters
3 Points
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
Feb 08, 2016 | Projection Televisions
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Projection Televisions
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Projection Televisions
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Aug 11, 2008 | Hitachi 51SWX20B 51" Rear Projection...
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Projection Televisions
Black Screen with vertical lines down the side?
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
218 people viewed this question
Top Zenith Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Zenith Projection Television Expert? Answer questions, earn points and help others
