Question about Alpine Air XL-15 Air Purifier
The yellow light in my alpine air 15sxl air purifier is off
Is that an important light? Do I need to get another bulb? The red service light is also on,but the purifier seems to be working fine.
5 Suggested Answers
Dutch7773
  • 31 Answers
SOURCE: I need Alpine Air XL-15 Air Purifier Repair service
Best bet is to call EcoQuest at 1-800-989-2299 and they can direct you to the closest repair center.
There is also a way to upgrade to a newer model the FreshAir 2.1 getting $100 back for your old XL-15.
To do this go to www.healthylivingia.com or call 1-800-798-6925 and ask for Eric.
Posted on Feb 02, 2009
  • 8 Answers
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Posted on Dec 25, 2009
  • 670 Answers
SOURCE: we have an alpine air purifier and the plate needs
Take a 1 part ammonia and 1 part water solution and an old toothbrush and dip the brush in the ammonia solution and scrub the metal grid on the plate to remove the deposits. Do both sides and then rinse with water and allow it to completely dry before reinstalling. Hope this helps.
Posted on Nov 05, 2010
JSEhandyman
  • 368 Answers
SOURCE: do not know what to do when the service required light is on on a Alpine LIVING AIR XL15 IONIC AIR PURIFIER OZONE XL 15. How do I service it?
Hi JoAnn,
Alpine purifiers need periodic cleaning, as dust and dirt from air moving through the unit is electrostatically deposited on internal components; enough build-up can cause short-circuits and diminished peformance. The ozone-discharge plates need to be cleaned monthly, and the inside wiped down at that time. The lint trapscreen on the back also needs to be cleaned (I use hot water in my kitchen sink with the spray-nozzle). I recommend an old toothbrush dipped in household ammonia for scrubbing the plates, and an old sock dampened with ammonia for wiping the inside spaces. The ammonia fumes can be unpleasant, so if you can do this outside or in garage, do so. Also, rinse the plates thoroughly to remove any ammonia residue. Just make sure the discharge plates are COMPLETELY BONE-DRY before putting them back in, otherwise, you risk shorts, and potential damage to the plate. Use the toothbrush without the ammonia (preferably dry) to dust-off the sensor in back that triggers the "service required" light. Iif it's like the ones I've worked-on, it should be connected to another light inside, but I recommend checking your owners manual to help identify the location and description of the sensor.
About once a year, a thorough cleaning (using a brush to get the accumulated gunk out of the nooks and crannies) is recommended). This involves disconnecting the fan leads and (if so-equipped) the needle-point ionier after removing the four screws through the bottome holding the chassis in-place. If you're not comfortable working with wiring and spade-terminals, you may want to use a keyboard vaccuum brush (long-necked tube with a brush on the end available in office-supply stores and the like) to reach in instead.
If this helps, please rate me... thanks!
Jon
Posted on Nov 28, 2011
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
Red light will not go off
The only other light I'm aware of is the light in the back of the machine attached to the radio frequency ionizer. This light lets you know that both of the ionizers including the needle point ionizer are working. When the light is off, it means the ionizers need cleaning or service. When I clean my machines, I always clean off both ionizers w/ a 50/50 solution of Ammonia w/ a paper towel. I do this the same time I clean the ozone plate. If you're machine is still under the 3 year warranty, you can send it back to be fixed for no charge except shipping. I hope this helps.
Jul 25, 2011 | Alpine Air XL-15 Air Purifier
How do I put in the light bulb in a Fresh Aire model?
According to Alpine Air, if the light bulb is one that indicates how it's function operation, there is no need to replace it, if the unit is working properly. The specific model you have is over ten years old and is not repairable. At least, not by Alpine Air. For more information and how to contact Customer and Technical Service, click on the following link. http://www.alpineairtechnologies.com/?gclid=CISY_5SR4acCFZIK5Qod7GEu-Q
Mar 21, 2011 | Alpine Air XL-15 Air Purifier
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Jan 13, 2009 | Alpine Air XL-15 Air Purifier
Living air classic
its still fine to use, there is a reset when the machine is serviced, just make sure filters and plates are clean
Jan 16, 2008 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
60 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Jeff Osterhout
Jeff Osterhout
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
