Om96431 parts Does anyone know where to get replacement cutters for the Office Max paper shredder OM96431?
2 Suggested Answers
SOURCE: Office max shredder om96431
For me, the problem was the sensor connections. I took the unit apart (7 phillips screws, I'm not sure why I didn't have to remove the 8th.) Then I took the paper sensor unit off (2 more phillips screws.) Then I removed the little black box that both sensor wires are connected to (1 more phillips screw.) Then I pried that box open with a flat head screwdrive. Some parts fell out. I put it all back together and it worked.
If you don't want to mess with it, just remove the two wires and tie them together. The unit will always be on when turned on to Auto, but that's better than not working.
Posted on Aug 27, 2008
I need new cutters
Hi, Please tell me the details that you need. I can not get which cutter you need.
Aug 26, 2011 | Office Equipment & Supplies
Cutters do not activate when paper is fed into slot for shredding Office Max model omo1288
make sure sensor switch is free and clear. unplug first before cleaning out. You will see little swith if you look inside where paper is fed in. GL
Dec 22, 2010 | OfficeMax 0M96431 Shredder
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
I have an office max shredder OM99729 that quit working. the motor runs but it won't pull the paper into the shredder. I opened the cover and found the gear is stripped that runs directly off the motor....
I have the same unit witht he same gear off the motor that has a couple of teeth srtipped. Anyone out there know where to get a replacement gear?
Thanks...
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
May 17, 2008 | OfficeMax 0M96431 Shredder
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
60 people viewed this question
k24674
jasbo
jasbo
