Question about Zodiac Pool Systems Pool & Spa
Pump not working
The filter is not working
  • Zodiac Pool ... Master
  • 1,631 Answers
What do you mean: not working?
Need more specific info...
Is it on, but not pumping water?
pump needs to be primed. That could be an issue all by itself!
Do you hear anything? Is motor working?
If not, check power, switch, breaker, wires.
if all good, bad pump motor.
Better specific questions asked to the point, get more definitive answers!
Posted on Apr 19, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Need more info does system have power to pump motor? if not check breaker if voltage from breaker check switch if you do have power to the pump motor sounds like bad pump motor
Posted on Mar 13, 2014
My pump and filter work great for an hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
take filter apart clean grids (use TSP then 4 parts water to 1 part muriatic acid rinse off put back together then recharge with DE it should be fine filters are locked
May 19, 2014 | Hayward EC-40 DE Pool Filter with pump
My pump and filter work great for aa hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
make sure filter grids where cleaned with TSP tri sodium phosphate to degrease them then recharge system filters are locked or try on recirculate if ok then clean filters if not pump seals getting hot and pump not working correctly
Intex pump flowrate drops
you may have a dirty filter. Check your filter to be sure. Remove the filter from the pool equipment and see if it runs fine for longer period of time. The filter would be the only restriction in your Intex system for water flow.
Rod
US Parts Center
Jan 17, 2013 | Intex 1000 Gallon Swimming Pool Filter...
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
My car cut off while driving. wouldnt start back up. check the gas line to the engine and no gas is coming through. what could be my problem and do i fix it
its the fuel pump going bad and also your fuel filter might need a new filter because if the fuel filter is plugged up to the point that the fuel pump is working too hard to try to pump the gasoline through the filter and can destroy the fule pump so if there is no gasoline coming through the gas lines that means check for filter and pump. Usually some times you can hear the fuel pump working on some models like a humming sound in the back of car.
May 24, 2011 | 1995 Buick Century
Pump and filter work fine. After shut down, pump
check for leak on intake union or pump top seal if ok bad seals in pump replace
May 23, 2010 | Sta Rite Pool & Spa
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Fuel filter or fule Pump?
i,d say start with filter first. if it was the pump it wil not run pump work or dont work
Apr 08, 2009 | 2003 Mitsubishi Outlander
Wash machine agitates but won't drain the water -- on any cycle choice. Machine makes noise like something is happening, but water remains.
Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Jul 07, 2008 | GE WCVH6260FWW
Pool & Spa Logo
240 people viewed this question
Top Zodiac Pool Systems Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Zodiac Pool Systems Pool and Spa Expert? Answer questions, earn points and help others
