Question about Astra Mega II Espresso Machine
Heating element for astra espresso machine mega 2 cs
SOURCE: Astra Mega II <----Need help!
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Posted on Sep 13, 2008
SOURCE: espresso extraction time
You will need to reprogram the computer. To do this, it is relatively simple. take your grounds and tamp into your portafilter (I usually start with a double). make sure that you tamp it correctly.
Then, hold down the start/stop button until you see the lights flashing on the panel (if you want to program both groupheads at the same time, then hit the start/stop button on the other side as well.) Then with your portafilter inserted in the grouphead, hit the button that you would like to represent your double shot. you should see a water stream about the width of a cooked piece of spaghetti. After around 18 seconds to 22 seconds, you should have your shot levels filled. then hit the button that represents your 'double' shot to stop it. then hit the start/stop button. You will see the start stop button flash a couple times and then turn off.
That should do it. remember, that the preferred timeframe for a shot of espresso is 18-22 seconds. Your setting on the coffee grinder would then need to be set to make sure your getting a full shot in that amount of time.
Good luck
SOURCE: I NEED AN OPERATION MANUAL FOR AN ASTRA MEGA II C ESPRESSO MACHIN
Hi, I'm new to the coffee business and justed purchased this machine and no manual as well.
I just called the astra manufacturer (1-877-340-1800 ) and they were going to e-mail me a manual free of charge. Hope this helps. J Howell
Posted on Jun 24, 2009
  • 7 Answers
SOURCE: Is the Astra Mega ll capable to pull a good shut with a 21g Basque?
Do it. It has the horsepower. You will probably just need to program the shots accordingly, and maybe get a deep basket for your portafilter.
Posted on Aug 29, 2009
  • 7 Answers
SOURCE: Astra Mega IIC startup issues
Go ahead and keep the sensor probe connected. Open up the steam wands before turning the machine on the let the air bleed off as it fills. The element should not turn on if the water level is too low and the circuit is working properly. As for the groups pumping water, try hitting the Brew Stop buttons. If that doesn't work, something may be wired wrong, or your group solenoids may be stuck.
My astra espresso mega 2 s boiler pressure is 0.
It is possible that the safety thermostat on the boiler has tripped. Reset safety thermostat and turn machine on. If reset is not tripped then it could be the element or the pressure stat are damaged.
Aug 01, 2014 | Astra Mega II Espresso Machine
Astra mega 2 tripping the main breaker
i would start by taking a ohme meter check the on ,off switch,if no problem ,go to the heating element check it ,if it ohmes out ok ,,then you have a dead short in the wiring somewhere.
Dec 03, 2013 | Astra Mega II Espresso Machine
The machine is blowing the main fuse, we think we need a new element and a side water gauge, but would like to talk about it. Thankyou
The easiest way to check the element is to remove electrical wires and then check for resistance on the element. Also you might want to check the pressure stat(its the black box with wires leading to the element and tube to the boiler).
Sep 21, 2011 | Astra Mega II Espresso Machine
My Astra Mega II Espresso Machine doesn't seem to be pumping water in when i turn it on it makes a distict click after a second
There is either 1 of 2 things going on:
1 - The machine does not need water or
2 - The inlet solenoid is damaged.
If the boiler is full the machine will not call for water, to test this you could remove the top panel and disconnect the level probe, then turn the machine on, if it calls for water then the boiler was full and it did not need anymore. If it does not call for water then the inlet solenoid is possible damaged. To Check the inlet solenoid which is on the bottom right of your machine, you can do a resistance check on the coil, to make sure it is working, and or loosen the output of the solenoid to see if water is flowing when it is calling for water.
Apr 03, 2011 | Astra Mega II Espresso Machine
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
Where to get it repaired?????
Try Mr. Espresso in Oakland, CA www.mrespresso.com. While they don't typically supply Astra, I believe they are familiar with the brand and can refer you to a technician if they can't service it themselves. Astra will also service their own machines, but you would probably have to ship it to their shop in LA.
Apr 17, 2009 | Astra Mega II Espresso Machine
I NEED AN OPERATION MANUAL FOR AN ASTRA MEGA II C ESPRESSO MACHINE
Jan 23, 2009 | Astra Mega II Espresso Machine
Nov 06, 2008 | Astra Mega II Espresso Machine
Sep 13, 2008 | Astra Mega II Espresso Machine
Astra Mega II
disconect the heatind element or elements on the live side and see if it still trips the 20 amp breaker. try that first.
Aug 27, 2007 | Coffee Makers & Espresso Machines
Astra Mega II Espresso Machine Logo
57 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
