Oce tds 300
Reset Printer 5502
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
SOURCE: oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Posted on Mar 08, 2010
  • 149 Answers
SOURCE: OCE TDS 600 error code 22017. Do you Know what it
There is a problem in the power supply section. Call for service, this is not user fixable.
Posted on Oct 05, 2010
  • 212 Answers
SOURCE: MY OCE TDS 400 PRINTER
damage of toflon of printer
Posted on Mar 11, 2011
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
Posted on May 03, 2013
What does error code 0820 on Oce TDS 100 stand for?
NTC Middle right of the fuser assembly. The NTC must be replaced. These are ceramic encased thermistors. Very expensive and easy to break. I recommend calling an authorized Oce technician.
Mar 22, 2018 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8505,i want A Solution
The NTC 2 is probably shot. These are ceramic coated thermistors and extremely fragile. I would recommend calling an authorized Oce technician to get this replaced.
Have a service manual for OCE tds 100 Copier?
No service manual, but go to downloads.oce.com and see what you can find there.
Jan 20, 2014 | OCE 3140 Copier
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
Oce tds 600 Error code 15504 machine stopped in the middle of a run (like every 5 sheets) could be an overheat problem
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Sep 02, 2009 | OCE Office Equipment & Supplies
Oce tds 800 how do you reset the counter for maintenance and part
hi
pASSWORD:675756
good luck
Yaacov
Mar 11, 2009 | OCE Office Equipment & Supplies
65 people viewed this question
k24674
jasbo
jasbo
