Question about GE WBSR3140DW Top Load Washer
Install clutch cable - GE WBSR3140DW Top Load Washer
    Master:
  • GE Master
  • 676 Answers
You have a clutchless 2 speed motor so what it is exactly you want to do? GE authorized.
Posted on Feb 13, 2014
How to adjust clutch inside primary case?
Because the clutch cable adjuster clearance increases with engine temperature, adjust
the clutch when the engine is cold. If the clutch is adjusted when the engine is hot, insufficient pushrod clearance can cause the clutch to slip.
1. Remove the clutch mechanism inspection cover and
quad ring
2. Remove the clamp and slide the rubber boot off the clutch in-line cable adjuster.
3. Loosen the adjuster locknut and turn the adjuster to provide maximum cable slack.
4. Make sure the clutch cable seats squarely in its perch at the handlebar.
5. At the clutch mechanism, loosen the clutch adjusting screw locknut and turn the adjusting screw clockwise until it is lightly seated.
6. Squeeze the clutch lever three times to verify the clutch balls are seated in the ramp release mechanism located behind the transmission side cover.
7. Back out the adjusting screw counterclockwise 1/2 to 1 turn. Then hold the adjusting screw and tighten the locknut to 72-120 in.-lb.(8-14 N•m).
8. Once again, squeeze the clutch lever to its maximum limit three times to set the clutch ball and ramp release mechanism.
9. Check the free play as follows:
a. At the in-line cable adjuster, turn the adjuster away from the locknut until slack is eliminated at the clutch hand lever.
b. Pull the clutch cable sheath away from the clutch lever, then turn the clutch cable adjuster to obtain the clearance gap
c. When the adjustment is correct, tighten the clutch in-line cable locknut and slide the rubber boot over the cable adjuster.
10. Install the clutch inspection cover quad ring onto the primary chain case cover.
11. Install the clutch inspection cover and tighten the screws to 84-108 in.-lb. (9.5-12 N•m).
Jul 23, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
After a gear oil change how do i adjust the clutch
quad ring
Jul 12, 2014 | 2003 Harley Davidson XL 1200 C Sportster...
Fix clutch cable
Removal
Raise the rear of the vehicle and support if securely on jackstands after loosening the lug bolts of the left rear wheel. Take off the wheel.
Find the clutch release lever on the upper left side of the transaxle and unhook the cable from the lever.
Remove the pedal cluster and unhook the clutch cable from the clutch shaft.
Pull the clutch cable forward, through the center tunnel, and out the hole for the pedal cluster.
Installation
Coat the new cable with multi-purpose grease.
Find the front end of the cable guide tube by reaching into the hole for the brake and clutch pedal cluster. Grasp the tube with your fingers and insert the new cable into the tube.
After you ve started the cable into the tube, push it to the rear, through the tube. If you need to, lubricate the cable with multi-purpose grease as you push it into the tube.
The "sag", or bend, in the clutch cable guide tube is important - the friction it imposes on the cable minimizes clutch chatter. To alter the sag, install or remove washers between the holding bracket and the end of the cable tube.
Now adjust the clutch pedal freeplay.
Apr 01, 2014 | 1960 Volkswagen Beetle
Clutch cable installation
  • Put your mower in the lowest position and open the hood.
  • 2 Lift up the retainer spring that holds the clutch cable to the adjustment bracket. Pull the cable out of the bracket.
  • 3 Remove the clutch cable spring from the idler bracket. Pry the spring open with a pair of pliers if necessary.
  • 4 Hook a new clutch cable spring over the idler bracket and squeeze it closed.
  • 5 Slip the clutch cable under the retainer spring.
May 04, 2013 | Husqvarna Garden
I installed new bars and cables on my 07 FXD. Im not getting a good clutch regardless of how much i adjust it. what else could be my problem??
Hi David, if you installed a new clutch cable they will stretch initially, for more information about your question please visit the websites below. Good luck and have nice day.
How To Properly Adjust The Clutch Clutch Cable Harley Davidson
Feb 12, 2012 | 2007 Harley Davidson FXD Dyna Superglide
How do you change a clutch cable in a 1989 mustang 5.0l 5 speed
Hi, procedure from autozone.com pasted below. Please let me know if you have any questions, and thanks for using FixYa.
CAUTION The clutch driven disc often contains asbestos, which has been determined to be a cancer-causing agent Never clean clutch surfaces with compressed air. Avoid inhaling any dust from any clutch surface. When cleaning clutch surfaces, use a commercially-available brake cleaning fluid.
REMOVAL & INSTALLATION
  1. Lift the clutch pedal to its upward-most position to disengage the pawl and quadrant. Push the quadrant forward, unhook the cable from the quadrant and allow it to slowly swing rearward.
  2. Open the hood and remove the screw that holds the cable assembly isolator to the dash panel.
  3. Pull the cable through the dash panel and into the engine compartment. On 5.0L engines, remove the cable bracket screw from the fender apron.
  4. Raise and support the vehicle safely using jackstands.
  5. Remove the dust cover from the bell housing.
  6. Remove the clip retainer holding the cable assembly to the bell housing.
  7. Slide the ball on the end of the cable assembly through the hole in the clutch release lever and remove the cable.
  8. Remove the dash panel isolator from the cable.
To install:
  1. Install the dash panel isolator on the cable assembly.
  2. Insert the cable through the hole in the bell housing and through the hole in the clutch release lever. Slide the ball on the end of the cable assembly away from the hole in the clutch release lever.
  3. Install the clip retainer that holds the cable assembly to the bell housing.
  4. Install the dust shield on the bell housing.
  5. Push the cable assembly into the engine compartment and lower the vehicle. On 5.0L engines, install the cable bracket screw in the fender apron.
  6. Push the cable assembly into the hole in the dash panel and secure the isolator with a screw.
  7. Install the cable assembly by lifting the clutch pedal to disengage the pawl and quadrant. Then, pushing the quadrant forward, hook the end of the cable over the rear of the quadrant.
  8. Depress the clutch cable several times to adjust the cable.
May 07, 2011 | Ford Mustang Cars & Trucks
Put a new clutch cable on my escort but no good as i can not adjust the pedal
LIFT THE CLUTCH PEDAL TO DISENGAGE THE ADJUSTING MECHANISM.THIS MUST BE DONE DURING CABLE INSTALLATION AS FAILURE TO DO SO WILL RESULT IN DAMAGE TO THE SELF ADJUSTER MECHANISM.INSERT THE CLUTCH CABLE THROUGH THE DASH PANEL AND THE DASH PANEL GROMMET.( WARNING ) BESURE THE CLUTCH CABLE IS ROUTED UNDER THE BRAKE LINES AND NOT TRAPPED AT THE SPRING TOWER BY THE BRAKE LINES IF EQUIPPED WITH POWER STEERING ROUTE THE CABLE INBOARD OF THE POWER STEERING HOSE.PUSH THE CLUTCH CABLE THROUGH THE INSULATOR ON THE STOP BRACKET AND THROUGH THE RECESS BETWEEN THE PEDAL AND THE GEAR QUADRANT.LIFT THE CLUTCH PEDAL TO RELEASE THE PAWL ROTATE THE GEAR QUADRANT FORWARD AND HOOK THE CABLE INTO THE GEAR QUADRANT.INSTALL THE CLUTCH SHIELD ON THE BRAKE PEDAL SUPPORT BRACKET.ON THE TEMPO OR TOPAZ INSTALL THE PANEL ABOVE THE CLUTCH PEDAL.USING A PIECE OF WIRE CORD OR TAPE SECURE THE PEDAL IN THE UPMOST POSITION.INSERT THE CLUTCH CABLE THROUGH THE INSULATOR AND CONNECT THE CABLE TO THE CLUTCH RELEASE LEVER IN THE ENGINE COMPARTMENT.REMOVE THE DEVICE USED TO TEMPORARILY SECURE THE PEDAL AGAINST ITS STOP.ADJUST THE CLUTCH BY DEPRESSING THE CLUTCH PEDAL SEVERAL TIMES.INSTALL THE AIR CLEANER.
May 31, 2010 | 1995 Ford Escort
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
GE WBSR3140DW Top Load Washer Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
