IDSTAT RTN number - Computers & Internet
I have a 2000 crown vic and my coolant fan wont come on unless i cut the a/c on or unplugged the cylinder head sensor i changed thermostat and temp sensor it still same thing what could be the problem
You have a wiring problem from sensor to the PCM - engine computer .
DL22 CHECK CHT SIGNAL CIRCUIT FOR SHORT TO GROUND
    Note: Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
  • Disconnect PCM.
  • Measure resistance between CHT signal and SIG RTN circuits and then between CHT signal and PWR GND circuits at the PCM harness connector.
  • the PCM is what controls the cooling fan !
  • This Pinpoint Test is intended to diagnose the following:
    • Cylinder head temperature (CHT) sensor (6G004)
    • Harness circuits: CHT, VREF, and SIG RTN
    • Powertrain control module (PCM) (12A650)
    Tables and Graphs
    On applications that do not use a ECT sensor, the CHT sensor is used to determine the engine coolant temperature in place of the ECT sensor. In this case the PCM may store both CHT and ECT Diagnostic Trouble Codes (DTCs). To cover the entire temperature range of both the CHT and ECT sensors, the PCM has a dual switching resistor circuit on the CHT input. A graph showing the temperature switching from the COLD END line to the HOT END line with increasing temperature and back with decreasing temperature is included. Note the temperature to voltage overlap zone. Within this zone it is possible to have either a COLD END or HOT END voltage at the same temperature. For example, at 90°C (194 °F) the voltage could read either 0.60 volt or 3.71 volts. Refer to the table for the temperature to voltage expected values.
    Voltage values were calculated for VREF = 5.0 volts. These values can vary 15 percent due to sensor and VREF variations.
  • DL1 DTC P1288 OR P1116: CHECK OPERATION OF CYLINDER HEAD TEMPERATURE SENSOR
    • Run engine at 2000 rpm until engine temperature becomes stabilized.
    • No Starts or Vehicle that Stalls:
      • GO to DL3 .
    • Check that upper radiator hose is hot and pressurized.
    • Rerun Key On Engine Running (KOER) Self-Test.
    Is DTC P1288 or P1116 present? Yes No GO to DL2 . Engine temperature was not stabilized. REPAIR any other DTCs as necessary. DL2 CHECK VREF CIRCUIT VOLTAGE AT TP SENSOR
    • Refer to schematic at the beginning of this pinpoint test.
    • Disconnect throttle position (TP) sensor.
    • Key on, engine off.
    • Measure the voltage between VREF and SIG RTN circuits at the TP sensor harness connector.
    Is voltage between 4.0 volts and 6.0 volts? Yes No There is sufficient VREF voltage. RECONNECT TP sensor. GO to DL3 . GO to C1 . DL3 CHECK RESISTANCE OF CYLINDER HEAD TEMPERATURE SENSOR WITH ENGINE OFF
    • Disconnect CHT sensor.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this pinpoint test for resistance specifications.
    Is resistance within specification? Yes No For No Starts or Stalls, RETURN to Section 3 , Symptom Charts.
    All others, GO to DL4 . REPLACE CHT sensor. You need a scan tool to do some of these tests
  • DL4 CHECK RESISTANCE OF CHT SENSOR WITH ENGINE RUNNING
      Note: Verify that engine is at operating temperature before taking CHT readings.
    • Run engine for two minutes at 2000 rpm.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this Pinpoint Test for resistance specifications.
    • Key off.
    Is resistance within specification? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPLACE CHT sensor. DL5 DTC P1289 OR P1290: ACCESS CHT PID AND CHECK VOLTAGE
    • Connect scan tool.
    • Access CHT V PID.
    Is the CHT V PID less than 0.2 volt? Yes No GO to DL6 . GO to DL7 . DL11 CHECK CHT SENSOR SIGNAL AND SIG RTN CIRCUITS FOR OPEN IN HARNESS
    • Disconnect PCM.
    • Measure resistance of CHT circuit between PCM harness connector pin and CHT sensor harness connector.
    • Measure resistance of SIG RTN circuit between PCM harness connector pin and CHT sensor harness connector.
    Is each resistance less than 5.0 ohms? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuits. free wiring diagrams at www.bbbind.com
Jul 13, 2015 | Cars & Trucks
Dfas my pay login
Your new bank can provide you with the advice and paperwork to do this.
Jul 02, 2014 | Computers & Internet
Bosch built in oven
ok try there maybe a recall list as there is with there dishwashers try the list see if ure model number is on the list then if it is either send it for repair or rtn it most people still are using recall listed units
Apr 25, 2013 | Bosch HBL5450UC Electric Single Oven
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
I got this Pacific Digital model 1930-24 in a yard sale. It needs a power supply/adapter. Where in canada can I purchase one and is this power supply common. I have a disc drive back up unit for my PC that...
Possibly not. It depends on what the power points are on the connector. The Pacific Digital 1930-24 uses the following pinout voltages: 1 = +12VDC ; 2 = +5VDC ; 3 = RTN/CMN ; 4 = +5VDC ; 5 = RTN/CMN. The pinout DOES NOT follow a clockwise or counter clockwise position. The pinout starts at the bottom with pin 1 by itself, above it is Pin 2 & 4 above that. On the opposite side is 3 with 5 on top. Or you can view the following image: http://img7.imageshack.us/img7/7204/minidin5p.gif
Again, that is the pinout for the socket on the 1930-24. Some iOmega external CDRWs have the +5VDC and RTN pins swapped. So they would not be a good alternative to use.
Jul 25, 2010 | Pacific Digital X-treme CD-RW Burner
Where can i get a ac adapter for a Pacific Digital 1930-48
If you can get an adapter with the correct connector, you could try to make your own power adapter, or even convert an iOmega adapter.
Mar 18, 2010 | Pacific Digital Computers & Internet
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Lost power cord
Ebay, or if you arent into auctions you can try directly from pacific digital, they can ship to you. Tell them you didnt have one when you bought it, maybe they will give it to you for free.
Aug 12, 2009 | Pacific Digital (U-30106) CD-RW Burner
What color are the wires for the iat sensor on a 2009 f-150 w/ 5.4 l
the iat is part of the maf sensor located in the air filter duct or housing. 6 pin connector. pin one color violet/gray is for iat. pin 2 is c-signal rtn yellow/violet. pin 3 maf yellow/violet. pin 4 maf rtn blue. pin 5 ground black/yellow pin 6 circuit breaker fuse 76 blue/brown
Mar 05, 2009 | 2009 Ford F-150
A Rtn Light
hold down the code key and press the "R" key (the key that has A RTN on it) this will turn the light on or off. when it is on, it means the machine is in "automatic return" mode, which means when you get within about 10 spaces of the right margin and hit the spacebar the printhead will automatically return without hitting the "return" key. those lights turn on when the mode, it indicates, has been turned on.
Nov 11, 2008 | IBM Wheelwriter 30 Typewriter
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
