Question about Kenwood Am Fm Stereo Receiver Tuner Amplifier Amp Kr-920b
No fm output - Kenwood Am Fm Stereo Receiver Tuner Amplifier Amp Kr-920b
Why cant I record FM from this Pioneer vsx921
To record from the built-in FM-tuner, you can use either the DVR/BDR or the CD-R/TAPE outputs of the receiver.
Mar 13, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
To add to my request a manual for AWA 17cm DVD/CD/AM-FM Television Micro System
An FM transmitter is a portable device, which converts a specific audio output into an FM radio signal. It can be plugged into a CD player, satellite radio system, headphone jack, or a portable media player. One common use of an FM transmitter is to play music from an Mp3 player through the speakers of a car.
Aug 20, 2012 | Televison & Video
Marantz sr 4000 powers up, but no sound
Try plugging in headphones, if they work, it sounds like outputs have blown,
Mar 18, 2012 | Marantz Audio Players & Recorders
Feedback through fm radio
try using a seperate ant for ur radios
Jul 20, 2010 | Radio Communications
Receiving AM & FM stations but NO AUDIO OUTPUT
Please post the make and model number of your radio to help us help you.
The more information you provide, the more specific and accurate our solutions can be.
Apr 15, 2010 | Audio Players & Recorders
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
FM output
The low signal may be due to loose connection of the antenna cable
Aug 29, 2008 | Audiovox Xpress Satellite Radio Receiver...
FM output
I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
Aug 23, 2008 | Audiovox Xpress Satellite Radio Receiver...
Kenwood Am Fm Stereo Receiver Tuner Amplifier Amp Kr-920b Logo
13 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
