Question about Astra Mega II Espresso Machine
Water heater for astra espresso machine - Astra Mega II Espresso Machine
5 Suggested Answers
SOURCE: Astra Mega II <----Need help!
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Posted on Sep 13, 2008
SOURCE: I NEED AN OPERATION MANUAL FOR AN ASTRA MEGA II C ESPRESSO MACHIN
Hi, I'm new to the coffee business and justed purchased this machine and no manual as well.
I just called the astra manufacturer (1-877-340-1800 ) and they were going to e-mail me a manual free of charge. Hope this helps. J Howell
Posted on Jun 24, 2009
  • 7 Answers
SOURCE: water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Posted on Aug 29, 2009
EsWorld
  • 1618 Answers
SOURCE: My Astra Mega II Espresso Machine doesn't seem to
There is either 1 of 2 things going on:
1 - The machine does not need water or
2 - The inlet solenoid is damaged.
If the boiler is full the machine will not call for water, to test this you could remove the top panel and disconnect the level probe, then turn the machine on, if it calls for water then the boiler was full and it did not need anymore. If it does not call for water then the inlet solenoid is possible damaged. To Check the inlet solenoid which is on the bottom right of your machine, you can do a resistance check on the coil, to make sure it is working, and or loosen the output of the solenoid to see if water is flowing when it is calling for water.
Posted on Apr 04, 2011
Have an Astra G.A.P. espresso machine and have replaced the pump. New pump will not pump water thru machine.
Sometimes a dry pump will; be a devil to prime up and start running. You may have to find a way to force the water into the pump. On the machines I worked on I had a hose the correct size to engage into the water tank socket on the machine. I would fill the hose up (about 2 feet) and blow as hard as possible while running the pump.
Oct 22, 2015 | Astra Coffee Makers & Espresso Machines
My astra espresso mega 2 s boiler pressure is 0.
It is possible that the safety thermostat on the boiler has tripped. Reset safety thermostat and turn machine on. If reset is not tripped then it could be the element or the pressure stat are damaged.
Aug 01, 2014 | Astra Mega II Espresso Machine
My Astra Mega II Espresso Machine doesn't seem to be pumping water in when i turn it on it makes a distict click after a second
Apr 03, 2011 | Astra Mega II Espresso Machine
Astra problems with water...
The gauge needs to be replaced, you might be able to do it if you have the part.
Apr 06, 2010 | Astra Mega II Espresso Machine
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
Where to get it repaired?????
Try Mr. Espresso in Oakland, CA www.mrespresso.com. While they don't typically supply Astra, I believe they are familiar with the brand and can refer you to a technician if they can't service it themselves. Astra will also service their own machines, but you would probably have to ship it to their shop in LA.
Apr 17, 2009 | Astra Mega II Espresso Machine
I NEED AN OPERATION MANUAL FOR AN ASTRA MEGA II C ESPRESSO MACHINE
Jan 23, 2009 | Astra Mega II Espresso Machine
Astra Mega IIC startup issues
Go ahead and keep the sensor probe connected. Open up the steam wands before turning the machine on the let the air bleed off as it fills. The element should not turn on if the water level is too low and the circuit is working properly. As for the groups pumping water, try hitting the Brew Stop buttons. If that doesn't work, something may be wired wrong, or your group solenoids may be stuck.
Sep 13, 2008 | Astra Mega II Espresso Machine
Apr 28, 2008 | Astra Mega II Espresso Machine
Astra Mega II Espresso Machine Logo
22 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
