Question about Car Audio & Video
Loud noise coming before start new song from usb pre amp
Each time when a new song start to plays, a loud noise seems to be appeared from the sub woofer and also speakers. Btw my I'm using pre amp with usb .What's is my problem actually?
    New Friend:
    Problem Solver:
  • 15 Answers
The problem is that you dont have proper earthing on the amp so that is why you will get a engine idling noise. you may need to put in a device called a supresser which will connect to the amp, or try using a 8 to 10mm earth cable from amp to the booth body for earthing. also make sure that you are not taking the earth from your car battery cause that will cause the noise aswell. hope this helps you.
Posted on Feb 18, 2014
3 Suggested Answers
tech48
  • 624 Answers
SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
Posted on Jun 17, 2008
  • 631 Answers
SOURCE: THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Posted on Sep 30, 2008
Loud whining noise
this could be due to a couple of problems but the most commen one is the layout of the wiring. the RCA cables coming from the radio to your AMP are probably routed with the 12v cable coming from your battey to the AMP so as you drive along it interfeers with the RCA cables. run the 12v cable down one side of the car and all the other cables down the other side. if this is not your problem it might be due to a faulty altenator which is overcharging and needs to be replaced. a temporary solution could be a noise filter.
read ther link below for more indepth detail on noise filters.
http://www.crutchfield.com/S-kWPVxOR1ggY/learn/learningcenter/car/noise_suppressors_installation_guide.html
Nov 01, 2013 | Kicker Car Audio & Video
KENWOOD KDC-X491
Have you tried a line noise filter? such as these
hope this helps
thanks for rating
Jan 14, 2008 | Car Audio & Video
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
Hello. My mirage sub just started to make a fuzzy noise when playing the bass...it happened after a party that played music on the sub very loud. I don't know what to do....help!
You have damaged the sub by playing it too loud.
Its either the map or speaker that has gone.
You should send it off to get repaired.
Please dont forget to vote this answer was helpful
Many thanks
Feb 20, 2011 | Mirage OMNI S8 Speaker
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Amp Turns off after 30 seconds of song play
Since the unit recovers once it has powered down. I suspect that the internal protection circuit is kicking in. Check the wiring and be sure that there are no crossed wires anywhere. These amps are designed to work with 2 ohm loads and can take a direct short for a short period of time. If the wires appear ok, measure the speakers with an ohm meter. If the speakers are 4 ohm rated, they should measure just under 3 ohms with the meter, If they measure less than 2 ohms, there is a problem with the speakers.
Also, does the amp shutdown regardless of the volume level or just when played loud?
Thanks,
Dan
Apr 15, 2009 | Kenwood 1000W Class D Bridgeable Mono...
Loud roaring noise
jack up front of car get hold of tyre an see if u get any play if u do u may get away with nipping them up a bit
Nov 19, 2008 | 1999 Mitsubishi Galant
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
