Question about Arris SURFboard SBG900 (49402201900) Modem
Motorola sbg900 won't login - Arris SURFboard SBG900 (49402201900) Modem
  • Jordan Mkt Dec 28, 2016
    Motorola Router tech Support phone Number 1877-778-8@9@6@9 for Motorola Router Customer Service.Click Here For Tech Support:https://goo.gl/GP13I5
Cant login to my motorola sbg900 wireless router. i know my username and password and it will not work. I've tried resetting it by holding the button down in the back, but that won't work either. i...
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
Trying to secure my wep, tried the loggin admin, motorola but will not log me in.
Couple of things you can do....
In the User ID field, type admin (case sensitive) and press TAB. In the Password field, type motorola (case sensitive) and click Log In to display the SBG900 Setup Program main window
If you are still having problems, try the following:
  1. Press the reset button on the rear panel. Resetting may take 5 to 30 minutes
  2. Try the login again, if that fail try from a different browser.
Mar 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Cant login to my sbg900, using admin for login but not recognising password
Try resetting the router. You can find a small hole with a button inside it at the back of the modem. Use a pin or a paperclip to press it for 5-10 seconds so that it will be restored to the factory settings.
Hope this helps! :D
Sep 08, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Sbg900 router, login problem
try to configure the browser settings, follow the steps below
1. Go to internet options and select the security tab
2. Highlight Internet and click customer level button
3. Scroll down to the very bottom, under user authentication select automatic logon with username and password
4.rest customer settings to medium
Jul 16, 2009 | Motorola Computers & Internet
SBG900 WITH WRONG PROVIDER SETTINGS HELLLPPPPP
Here is the complete manual.
http://broadband.motorola.com/consumers/products/sbg900/downloads/sbg900_user_guide.pdf
You want page number: 22
This is the Wizard mode that asks you questions and configures the Modem.
This is a great Cable modem, by the way.
Please rate this solution!
Jul 03, 2009 | Arris SURFboard SBG900 (49402201900) Modem
I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
May 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Wireless light does not come on
are u able to detect your wireless network in view wireless networks
if not login the modem setting and check whether the modem wireless is enabled.
if still having problem contact 9444482052..........jammy
May 17, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Sbg900 won't connect with wep enabled
This modem's remote router has a seperate firewall of it's own so what you'll have to do is; go to the to server site @ http//:192.168.100.1 then hit enter. you will go the the Login Site and you login and can reset or retrieve your WEP key.
Nov 25, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
138 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
