Question about Maytag SAV5710 Top Load Washer
I have a Maytag Bravos washing machine model #MVWX500XW1. Recently the spin cycle was sounding louder than usual like a bearing going out. By the weekend the clothes would not spin. I opened it up to find oil from the drive motor all over the motor and belt. I replaced the motor and everything was working again except for the same loud bearing noise. Is there a main bearing for the basket and is this common for this model. It's only 2 to 3 years old
SOURCE:
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
  • 239 Answers
SOURCE: washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Posted on Apr 24, 2010
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
How to replace drum bearings on a maytag bravos xl washing machine?
Not just the bearing, you need the rear tub assembly and basket in case the shaft is damaged
Aug 19, 2014 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
MAYTAG BRAVOS QUIET 300 VERY LOUD WHEN IN SPIN CYCLE
spinout bearing bad if noisey in spin only whole tub must be repaired
Feb 16, 2013 | Maytag Bravos 3.8 Cu. Ft. Washer
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag SAV5710 Top Load Washer Logo
548 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
