My C80 will not hold a fix for more than a couple of minutes. It's always worked fine for the last 5-years. It will lose a fix but still show the boat location. I've checked all the connections.
Hello!I bought 12 years ago a SONY TV KV-28FX60D with out any technical issue so far.The last couple of days I powered on and after five minutes it starts showing only half of the screen, losing the bottom half of the picture. what do you think it might be. Can you suggest a part to be replaced and if it is worth fixing, cost wise? Thanks KONSTANTINOS
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall.
ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
