Question about Dewalt Heavy - Duty 1.1 Hp Continuous 4 Gallon Electric Hand Carry Compressor - D55151
Dewalt compressor will not fill with air - Dewalt Heavy - Duty 1.1 Hp Continuous 4 Gallon Electric Hand Carry Compressor - D55151
3 Suggested Answers
  • 1388 Answers
SOURCE: Air Compressor
Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
Posted on Apr 01, 2009
  • 8404 Answers
SOURCE: how to fix compressor air gas 55 hp dewalt it
that is probably the top end for this machine. If not sure, visit the web site of the manufacturer.
Posted on Oct 10, 2009
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
I have a dewalt air compressor model d55155 will not bulte up any presure changed the cold start valve and the reed valves but not the reed valve plates it seemes like like now i have air coming out the...
If you have oil coming out of the oil fill and dip stick you most likely installed the reed plate upside down. Usually it says this side up or there is an arrow pointing up on the reed plate.
This is a good sketch of compressor and reed valve assy.
http://www.about-air-compressors.com/images/1055.gif
Usually the reeds are on top of the plate facing downward. If you have just a reed disc.. then the disc will need to be inverted.
Thanks for Choosing FixYa.
Kelly
Aug 18, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Tank wont fill with air but compressor runs
Can you hear the air coming out? Or it is not pumping up at all? If the air is not coming out somewhere like the bypass or the regulator, or the drain plugs, then the reeds are shot in the head, it is an easy fix, and an easy part to get, I hope, call Dewalt's hotline and tell them what's happening, they will fix you up.
Mar 08, 2010 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Air Compressor
Apr 01, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Dewalt compressor not filling with air drained tank closed valve
Some dewalt air compressors with single cylinder are known to develop trouble with reed valves and /or failed gaskets in head. Parts lists and parts are available at WWW.toolpartsdirect.com Simple test is to remove air filter and check for suction at intake. Bad reeds will tend to blow air out intake as pressure increases. Failed gaskets in head will cause very high temp at discharge hose. Parts are not too expensive. Enjoy
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Dewalt compressor not filling with air constantly running
hi your problem seems to lie with the valves in the cylinder head not sealing i suggest you obtain a new valve set and replace said items
hope this helps
if you do not have any air leaks and it is a oil less compressor than it is most likely the piston seal is wore out. if it is an oil compressor that it is likely a flapper valve
Dewalt Heavy - Duty 1.1 Hp Continuous 4 Gallon Electric Hand Carry Compressor - D55151 Logo
21 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
