Question about InFocus IN102 DLP Projector
Switch on lcd power is on but off lcd below one minute
I have a HP ZR24w LCD display that flickered on an off a for a few seconds and then finally died. Any advise would be appreciated.
To help you troubleshoot the display flickering on and off issue, Please follow the steps given below:
- First of all it is recommended to check if LCD power cable is attached correctly and firmly to LCD power connector and LCD power switch.
If issue persists, Please follow the steps given below:
- Please replace the power cord and try changing the power switch point.
- Make sure there is no power supply trip occuring in electricity source.
If issue persists, it is recommended to contact 'HP Support Center' for further assistance and you can also replace the LCD if it under warranty. To help you check warranty status, please find the link given below:
http://support.hp.com/us-en/checkwarranty
To help you contact HP Support Center, please find the link given below:
http://www8.hp.com/us/en/contact-hp/contact.html
GuruAid.com
Jun 23, 2016 | HP Z Computers & Internet
My printer has an error with error code E42 how can i fix that? pls help..
E42 I believe is a scanner error. Try first to switch it off for 30 minutes and try. Else re-attach the ribbon cables of the scanner and try again.
If error still persist then do a factory reset as per below
1) Switch off the printer
2) Press and hold the Stop/Reset button while switching on the printer.
3) With the Power LED lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) Release the Power button and the Stop/Reset button that will put the printer in service mode. Just wait for the menu selection.
5) When the LED lights in green, press Stop/Reset button to specified number of time(s)
according to the Legend below.
Legend:
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 13, 2011 | Canon PIXMA MP160 All-In-One Printer
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
TOSHIBA SATELLITE M55-S3512 LAPTOP LCD SCREEN is red then it switches off. When I close and reopen the lid the screen turns on for 3 secondes then goes off. Do I need to change the lcd?
hi,
Please try to remove the battery and the AC adapter then press and hold the power button or the on/off button for one minute. Basically,it will not turn on since there is no power supply connected. After one minute, connect the laptop directly to the power outlet without using the battery just for the meantime then power on the laptop, if this will not fixed the problem, you will need to replaced the LCD cable or the LCD itself.
Hope this will help...
Jan 08, 2011 | Toshiba SATELLITE K000080220 LAPTOP LCD...
Sony KDL-40V5100 Switches off by itself
Sorry to say but it sounds like your power supply is bad, although it is possible it is some other components in the TV because turning it off allows all diodes etc to power down completely. Unfortunately after a bit it happens again which leads me to believe again power trouble.
Nov 05, 2017 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Blank display
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Nov 06, 2009 | Nokia N70 Cellular Phone
Canon pixma pm500, error code 5200. inocrrect rpint head/ did corrective measures as per canoin usa website (remove ink cardtidges, remove then put back print head etc...still rec error code 5200.
Issue: ERROR LCD: Error Code 5200
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. Issue: ERROR LCD: Error Code 5200
    Solution: The MP500 may require repair
    Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.Find a Service Location
    If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
    • Obtain Support by Email
    • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. Eastern Time, excluding holidays).
Aug 20, 2009 | Canon Pixma MP500 All-In-One InkJet...
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Apr 18, 2008 | Samsung Syncmaster 192N 19" LCD Monitor
InFocus IN102 DLP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
