USB Device not recognized? eMachines ET1352-53
Just all the sudden started showing this message and I don't have anything else plugged into computer that isn't working.
    New Friend:
    Problem Solver:
  • 8 Answers
My usb device recognized
Posted on Feb 12, 2014
fidoliedo
  • 162 Answers
SOURCE: usb 2.0 ports not working on my emachines T3504
You may need to uninstall your current usb's and let Windows redetect them.
click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on tab HARDWARE, click on DEVICE MANAGER. Scroll down to UNIVERSAL SERIAL BUS CONTROLLER. Delete everything there. Click on ACTION, SCAN FOR HARDWARE CHANGES. It should redetect and you should be good.
Posted on Jul 26, 2008
Murdock_4
  • 12 Answers
SOURCE: USB Ports don't recognize typical thumb drive, mass storage devices
I'm not completely sure, but this may be a result of faulty drivers.
Try googling the brand name and the word: "Driver"; along with any other details about the device. (Model No. et cetera.)
Posted on Jul 31, 2008
SOURCE: My USB ports don't work
good day,,
your usb port has the problem.. try to follow this steps:
1. Try to check if the usb bus is installed, to do this right click on my computer
2. Click manage
3. Click Device manager
4. On the right side click on the plus sign of the universal serial bus controller
5. Check if all the item is in correct
if you are done and then the problem is still the same,try this one
1. Re-install your motherboard chipset
2. Ensure to install and try to look if the computer install the usb serial bus controller
tanx..
Posted on Jan 31, 2009
  • 166 Answers
SOURCE: I have no audio device recognized on my computer
you need to go to control panel and system and look for the yellow question mark, this is your soundcard, and there is no driver loaded. the easiest way is to look for a driver or cab folder on your hard drive unless you did a total wipe out as usually it will keep it and look for the one inside that says sound and look for the setup. if you cant find it, remove the sound card and write down the numbers and who makes it and then go to yahoo and type in
XXXXXXXX xp driver. DO NOT use a vista driver. you can also try clicking on the device and reinstalling the driver and when it askes, go online to find, if its common sometimes this works. you wont have any sound or settings for sound until you load the proper device driver
Posted on Sep 01, 2009
Testimonial: "Hey mate, Thanks for the assist. You're input was damned valuable in figuring out my mess!"
ericvb2005
  • 194 Answers
SOURCE: All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Posted on Oct 28, 2009
Usb ports not recognized
Did this suddenly start to occur? Were they working before? If so, it is very simple - shut down computer, remove the battery and unplug any power source, wait a couple of minutes and reassemble and power up. Wala! I read all kinds of complicated instructions, started with the simple, and problem solved.
Feb 22, 2010 | Computers & Internet
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
May 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Samsung YP-T7J MP3 suddenly doesn't work with USB on PC
hi
i have a samsung yp-t7j but i don`t know how to turn on .please help me
thank you
Nov 19, 2008 | Samsung Yepp YP-T7JX MP3 Player
USB External storage device not working properly
please update the USB Drivers and if that Doesnot Work then Update the BIOS of you Computer from the Manufacturers Web site
Nov 01, 2008 | Dell Computers & Internet
Barbie girl mp3 player isn't recognized in Windows
remove the backplate, get a pin and push the reset button at the back of the barbiegirl
Sep 10, 2008 | Mattel Barbie Girls MP3 Player
Usb ports
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
Jan 28, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
