Question about Lowrance Elite-5x Dsi Fishfinder
Cannot find bottom
Will not find blottom and DPH number constantly flashes the same number
Tip
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
on Jan 05, 2009 | D-Link DPH-540
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Can't get the D link DPH 540 TO GET A CONNECT TO WI FI
Dear Stoneway,
First create a network profile if not yet done so
Menu > Profile > Network Profile
then edit it, go to Account Choice and select "Default".
The "No SIP Account" error most likely comes from having a blank field in "Account Choice".
It's easier to set up the DPH-540 from the web admin interface, so you can try first to at least get an IP address assigned to the phone then use that IP address to access the phone from another laptop on that same wireless network. But again by the time you manage to thumb your way to get an IP address assigned, you have 3/4 of the problem already resolved so you may as well thumb in that finishing touch :-)
Viet
Jan 24, 2009 | D-Link DPH-540
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
Southern Telecom Phone DPH-201 wired 13 memory phone
The manual doesn't seem to be available online, but you can contact the manufacturer directly: http://www.southerntelecom.com/contact.htm Here is a link to their product page for your phone: http://www.southerntelecom.com/products/cordeddph201-1.htm
Mar 25, 2007 | Southern Telecom DPH-201 Corded Phone...
Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
Jan 11, 2007 | D-Link IP PHONE DPH-70S WITH BUILT IN...
Lowrance Elite-5x Dsi Fishfinder Logo
24 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
