I need a base stand
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
SOURCE: i lost my stand base
kindly contct with local sales n service provider or search on www.madeinchina.com
SOURCE: I have a 42 in. Vizio Galleria and need to remove
1. Unplug all of the cables and cords from your GV42L
FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and
flat surface (blanket, foam, cloth, etc) to prevent any
damage to the TV.
3. Pull the stand cover off by squeezing the sides to
release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws
(screw's specs: M4, 0.7 Pitch,
15mm long) so that the stand
base can be removed.
5. Gently remove the stand
base
6. Now, the GV42L FHDTV10A can fit securely to a
mount (sold separately) by utilizing the mounting
holes in the center of the back panel of the TV.
Please make sure to read the instructions of your
specific mount to properly hang the GV42L
FHDTV10A
SOURCE: vizio tv parts
i would send a email to [email protected] they should have the base stand for that model
