Question about Neff Ovens
NEFF HBB-AP 72-7 - Neff Ovens
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 | Neff Ovens
Unable to remove light cover inside oven
I'm not familiar with that oven model, but as I have had a similar issue with my Neff oven light, I thought I would give you the benefit of what I had discovered. The light cover in my oven is a round, thick glass cover. The hand book has a graphic showing that the cover is simply twisted with one hand in an anti-clockwise direction as viewed straight onto the cover. No way! The first issue is that the lamp housing is right in a tight corner and getting sufficient grip on the cover is tricky. I put rubber gloves on to increase the grip and resorted to using two hands to exert as much force as I could manage, but it only moved a small amount. I think the movement was only the entire lamp housing moving in the oven wall, rather than any movement of the cover. I tried warming up the oven (not too hot) in the hope that the cover might release due to expansion, but no go. I then wondered if cooking grease / deposits and bonded the cover to the holder; although it appeared reasonable clear. This appears to have been the issue as I applied WD40 to the seam where the glass meets with the lamp housing and left it for a few minutes. It needed a second application, but eventually came free. On inspection, there was only a minor 'varnish' on the glass that appeared to have prevented the two parts from moving. Using WD40 weakened the bond eventually, but it also made the glass incredibly slippery, so gripping the glass cover after application is difficult. I used the rubber gloves and wiped the glass well to remove any residual WD40 prior to attempting to twist the glass cover off.
Oct 06, 2014 | Neff Ovens
Need a manual for a neff fan assisted oven
Hi, Same can be found on neff website, Please find the same.
http://www.neff.co.uk/getting-started-with-your-neff-oven.html
Aug 25, 2014 | Neff Ovens
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
How do I set auto timer on my neff oven to come on In a couple of hours ?
Here is the link to a short PDF file that explains a couple of setting on the Neff oven, including the automatic timer:
http://www.neff.co.uk/files/Getting_Started_Leaflet.pdf
Hope this helps. :)
May 20, 2012 | Neff Ovens
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
No Instruction manuals
Down load them from Neff.
http://www.neff-home.com/uk/service/manual
Then you can print them.
Aug 04, 2017 | Neff Ovens
Ovens Logo
88 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
