Question about Motorola Radio Communications
Cp150 frequency change
How to change frequency
  • Motorola Master
  • 1,654 Answers
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Posted on Jan 08, 2015
I CANNOT CHANGE CHANEL BY KEYPAD
cp200, cp150 and p040 dont have keypad
Dec 16, 2013 | Motorola Cp200 Cp150 P040 Gp2000...
On my rca 54 tv in the cp150 chassis is a 35v 1800uf capacitor did they change ?
yes they also used a 2200UF 16V for CP150 cap either cap can be replaced with each other and it will work fine.
Jan 31, 2013 | RCA D52W19 52" Rear Projection Television
Standard Horizon CP150 internal battery is dead, so I can't save my waypoints. Has anyone ever changed the internal battery? What kind of battery is needed? Where is the battery located? How do I...
You must open the unit up to get to the battery .
The battery should be a 3 volt lithium cell that is soldered directly to the main circuit board .
If you are not experienced in electrical - DO NOT ATTEMPT .Take it to someone experienced .
If you need assistance call 1-800-701-4008
Sep 13, 2011 | Standard Horizon CP150 GPS Receiver
Can anyone explain the step-by-step replacement of CP150 capacitor?
The cp150 is located on the deflection board.( far right side circuit board) You will have to remove the deflection board and unsolder the old CP150 and then resolder in the new CP150. Observe polarity. Also should repalce CP114 and CP120 with the CP150. You can get that repair kit at www.tvrepairworld.com which has the three capacitors, and the CD with detailed instructions with photos. The CD also contains the service manual and other service information.
Dec 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
My 52" RCA rear projection TV will not turn on. Why?
Check cp150 on the Deflection board its the first board to left on bottom. If cp150 is puffed up on top then it is bad so repalce cp114 and cp120 also cp150 2200uf 16v other 2 caps 220uf 35v.
Dec 30, 2008 | RCA D52W19 52" Rear Projection Television
Rca 52 inch projection
I found that CP150 was bad. When looking at it, it is located on the left side board, on the right side of that board in the middle of a C shaped heat sink. When looking at the capacitor it was easy to tell that something was wrong because the top was puffed up. I replaced it with a new one (16 Volt, 2200uF) and it was working again. The part cost less than 5 bucks an took about 10 minutes to replace
Jul 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
