Question about Canon Office Equipment & Supplies
Lcd canon ir4570 blank - Canon Office Equipment & Supplies
What means this code E000225-0001 ?
The light intensity of CIS is faulty.Disconnect and than connect flexible cable,if necessary replace it,or replace reader controllerPCB
Jul 11, 2015 | Canon ImageRunner 4570 | IR4570 |
Ir4570 email
Sorry, wxygzgc, but there is no indication at all in the Users' Manual that the IR4570 has any email capability.
http://www.agercopy.ro/poze/24547_1_Manual%20Utilizare%20IR%202270_2870_3570_4570.pdf
May 20, 2014 | Office Equipment & Supplies
Canon ir4570 ir3570 ir2870 ir2270 service manual
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Apr 12, 2014 | Canon imageRUNNER 2870 Copier
Error code ir4570
mohon tdibantu untuk mengatasi E0024-001 untu ir4570 terima kasih
Sep 18, 2013 | Canon Office Equipment & Supplies
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
Dpi scanner setting for canon ir4570 location?
For scanning doc.s it can changed in network scangeartool, for copier/ printer it was in copy/ print setting under user settings,
Jul 07, 2009 | Canon Office Equipment & Supplies
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
May 21, 2009 | Canon Office Equipment & Supplies
16 people viewed this question
old marine
old marine
