Question about Optics
V3 not jolting
Rangefinder no longer jolts
  • 115 Answers
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Posted on Mar 13, 2014
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
Jacuzzi start/run capacitator what does it do
to develop the start torque needed to run a two hp or more motor a capacitator is used to temperarly boost the power up(faster than a human can do it) so that motor gets a short extra jolt of power so it can start to turn , unfortuniatly these "caps" dry out in a few seasons from all the heat they make in use and no longer give that "Jolt" needed motor fails to start to move and they require replacement to makeit right again
May 24, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Buschnell
If the jolt (vibration) doesn't work on your Bushnell V3, follow the instruction steps to change the unit of measure. (On the initial screen, hold down the "POWER/FIRE button, and it will cycle through your choices.) It flashes 3 times on each option. The first option is "Yards w/JOLT" even though the choice is abbreviated on the screen. Per the instructions, by releasing the POWER/FIRE button, you select your option. Wait until the 2nd flash on this choice to release the POWER/FIRE button, and the JOLT feature will be turned back on. (On mine, it didn't work by letting go on the first flash.)
Mar 23, 2014 | Bushnell Tour V2 Pinseeker Laser...
My shoprider jolts and shakes on reverse it is only 3 months old
The result of data corruption that can occur when power is low enough to get interupted by the load of a motor. The above solution it the correct thing to try first/
Jul 11, 2012 | Shoprider SL73 Echo 3 Wheel Scooter ()
When i put down the throtle the motor jolts like the hole van jolts unles i put the throtle down more it smoother it self out again but when i take it off again it jolts again pritty bad as well its just...
Replace the throttle position sensor . The engine computer is switching the injectors on and off , hence the jolting effect . The throttle position sensor is giving false information to the computer . Replacing the throttle position sensor will probably solve your problem .
Apr 25, 2011 | Kia Cadenza Cars & Trucks
My bushnell wasnpt working great this morning and then it stopped. I replaced the battery and it still doesn't work. I'll replace the batteries with new ones soon but was wondering if there is something...
The Bushnell Tour V2 is notorious for suddenly stopping operating. Normally, if I slap the sides it starts working again. This has happened many times. However, two days ago it quit working again and I have slapped the **** out of it and it still doesn't work. I have checked the batteries and they are great. Try slapping. If someone out there knows something else that will help me, please let me know.
bill
Sep 18, 2010 | Bushnell Tour V2 Pinseeker Laser...
I was driving home the other night and my jeep suddenly jolted. What could have caused it? My rear main seal has been leaking for some time and i finally got the fixed yesterday.They did the rear axle...
Last time I checked a jolt wasn't a factory option...Last time I felt a jolt, I'd broken a spider gear in the differential! That dosen't mean that that's what you have...There are numerous reasons for that and if you hear or feel anything unusual I'd have it re-checked immediately. A single jolt with no other symptoms is very hard to track down or diagnose if it left no other "footprints" behind.
It wouldn't hurt to have the shop that did the work at least give it a once over.
Sep 30, 2009 | 1995 Jeep Grand Cherokee
Final drive knocking/jolting
Does the engine's sound working follows this jolting or it does nothing to do with it?If you close your eyes can you hear the jolting (not as a metal sound but as an engine's hick up)?
May 27, 2009 | 1990 Honda CBR 600 F(1)L
1996 cbr 600 f3 second gear jolts the bike!
Shifting Fork may be bent or wore out, It also may be the Synchronizer that "holds" it in gear went bad. The Gear could be wore out or Warpped also.
May 12, 2009 | 1998 Honda CBR 600 F(3)W
Optics Logo
539 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
