Question about HP Pavilion zd8000 Notebook
No Boot. AHHHHHH
Hi everyone.  Need some help with this one as I am stumped.  HP Tech Support is a JOKE.
Here is what I have.  Turn on the power and the system POSTs fine. After the POST screen, it goes to a blank screen and you see the cursor in the upper left corner blinking.
Here is what I have done:
Changed Boot order
Reseated Hard Drive & CD Rom
Replaced, Reseated, and swapped Memory
Reset to default CMOS
Tried with Battery out.
Tried with less memory
Any help please.
Thanks
Adam
  • 1 more comment
  • Adam Smith Oct 27, 2007
    I have attempted to run without the hard drive as well.  Still no luch.  Just goes to the same blanks screen after post.
    That did not work.  I can get in the BIOS fine and play there.  I can not boot from CD or HD.  How would I flash the BIOS?
  • Adam Smith Oct 28, 2007
    Still having the same issue and don't feel that CMOS flash would work as the CMOS seems to be fine
  • 70 Answers
I am assuming that you can see the HDD, CD, etc. in the BIOS.
If you can, then you may have issues in a few places.  The most common would be the master boot record, however, you should be receiving an OS not present error, or similar.  I would put my money on a IDE controller problem, or as eagle338 mentioned, RAM.  There isn't much else that it could be.  Do you get any activity on the drives at all during boot?  Try without the CD drive attached, and if you have a USB device that you can boot from, unplug everything and try that.  The USB device will rule out the IDE controller if the machine still doesn't boot.
Posted on Oct 28, 2007
  • 4,889 Answers
Oh my...This is really strange..anyways this might happen sometimes if the edges of your memory chips are oxidized..Try this..Plug em' out take and eraser(yes and eraser) and rub the ends of your memory chips and then put it back..Let me know if it worked so that we can proceed further..
Also if you have a bootable CD put it into your drive and try booting from it if it doesn't boot then its probably a problem with the bios and i will help you flash it..
Posted on Oct 27, 2007
  • eagle338
    eagle338 Oct 28, 2007
    You can try what pattersj78 has suggested if you wanna check if its the problem with the IDE controller...IF its not the problem with that then i bet it is problem with the BIOS...and you will have to flash it..Its a problem with the I/O unit and do no not forget that BIOS=Basic Input Output System...
My hp compaq la2306x monitor has smoke coming from the back when i connect to the power.it works well. what is the problem?
Switch it off as soon as possible and don't use it till you found what is smoking. Unless someone was blowing smoke as a joke, smouldering something inside won't take long till it burns or makes a shortage, what in turn can blow the power supply.
When you don't have the skills to repair electronic things, please ask a tech to see what is wrong, before it is defect complete.
Apr 06, 2015 | HP Computers & Internet
First, let me just say that I LOVE this site. THANK YOU to everyone who shares their insight and knowledge to help the rest of us tech-illiterates of the world! Now I'm hoping some of you can help
All that you need to do is complete the alignment process. Press the Setup Button on front panel of printer. Go to Tools - Press Ok - Select - Clean Printhead ( or Align printer ) and Press ok
This should fix the issue
Regards,
Sean
Mar 02, 2013 | HP Photosmart C5180 All-In-One InkJet...
When i start stump grinder it works fine. when i start grinding a stump it pops, backfires and loses power. any suggestions?
Hi it looks like i had the same problem with my 252 and we replace the wire harness and got the problem fix.
Nov 24, 2012 | Vermeer Sc 252 Walk Behind Self Propelled...
Toshiba Plasma TV HP 42 Inch pop no picture
Most common issue is power supply board fails--Plasma sets do not sell single parts--only a complete board---may need a tech or shop to look and determine what is wrong.
I can suggest things but need to know your skill levels--this is not for everyone....
Nov 08, 2012 | HP PL4260N 42 in. Plasma HDTV
Hp mini 311-1000nr won't boot from dos
Restart and press Del or F2 or F4 frequently for enter to bios setup.
select boot piority for cd rom and insert bootable cd and press f 10 for save changes,Now press enter for boot from cd rom .
Hope this helps ,
Let me know if you need more information Thanks
May 11, 2011 | HP Mini 1000 Netbook
HP dv6000. Will not turn on. Clicks on for two or so seconds and turns off
Remove the battery and the power plug, now replug in the power plug alone and attempt to boot. If the laptop starts then the issue is the battery. If not the laptop has failed and you'll need to contact HP for service or a local service tech if it's outside of warranty. -Ravi Shanghavi, Ottawa
Aug 18, 2010 | HP Pavilion dv6000z Notebook
Dv55237cl blinking power led no boot
I would need some more explanation on this kind of issue.
It seems u have performed most of the steps to isolate the cause of the issue.
are you getting BIOS ???
if not...I guess there has to be something with the motherbaord.. then u need to check the follwoing recall program from HP. if ur laptop is in that then u can get the discount in repair otherwise u need to really concern the local tech to replace the MB.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Please check with it.. also can u please provide the product code of ur noetbookso tht i can search the MB..
Dreamkam
May 20, 2010 | HP Pavilion dv9000z Notebook
Like everyone else, my laptop is less than 2 years
You need to address this situation to HP - chat with an agent concerning your problem ...
start here ... http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&cc=us
Oct 16, 2009 | HP Pavilion dv2000t Notebook
HP a1600n desktop will turn on but will not boot. Does not run thru BIOS, keys/mouse check. HDD spins up, CDROM goes thru check then just sits. Monitor doesn't kick in because doesn't get to video check....
you need to open up the case, and remove the CMOS battery ( a silver wafer-style battery about the size of a quarter) and leave it out for about 10 minutes. put the battery back in and close the case back up and DONT mess with ANYTHING ELSE. if the computer STILL wont boot, then your motherboard is bad, and will need to be replaced through the manufacturer of your PC.
Sep 24, 2009 | HP Pavilion a1600n (882780776265) PC...
Cartridge Error
I hate to be blunt, but buy another printer other than HP. I have the same model and HP tech support could not help me. Even after tech support replaced the printer and the power supply, the problem persisted. My story is very long and may seem complicated to the average user. I am an expert in the computer field.
Jul 23, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Pavilion zd8000 Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
