Question about Inverter Electronics - Others
Short backup time - Inverter Electronics - Others
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Battery problem
Posted on Feb 03, 2015
Every time I start my 06 equinox the 10 amp backup fuse blows. When I try to restart the car its no crank no start. When I replace fuse it starts fine again. Why is 10amp backup fuse blowing?
A short circuit in the wiring . Do you you know how to test automotive electrical circuits ?
10 amp backup fuse ?????? back up lights ? Video's on youtube showing how to find an fix a short . Park neutral safety switch
The transaxle control module (TCM) primarily controls shift points and lockup engagement.
The transaxle is controlled by an electronic shift system. The TCM processes input signals. From the information received, the TCM controls the transaxle hydraulic system.
The electronic shift system consists of the following components:
• TCM
• Shift Solenoid (SS1 and SS2)
• Pressure Control Solenoid (PSC)
• Lockup Solenoid
• Input Shaft Speed (ISS) Sensor
• Output Shaft Speed (OSS) Sensor
• Transmission Fluid Temperature (TFT) Sensor
• Park/Neutral Position (PNP) Switch
Have the vehicle checked for DTC'S - diagnostic trouble codes
When the TCM detects an invalid combination of TR switch signals, then DTC P0705 sets. DTC P0705 is a type A DTC.
BACKUP Fuse
10A
PNP Switch
The transmission range (TR) switch is part of the park/neutral position and back-up lamp switch assembly and is mounted on the transmission manual shaft. The TR switch is a multi-signal switch. The transmission control module (TCM) supplies voltage to the TR switch. Each gear selector lever position grounds one or more of the signal circuits in a unique pattern. In order to determine the gear range selected by the driver, the TCM compares the voltage combination on the signal circuits to a TR switch combination table stored in memory. Refer to Transmission Range Switch Logic .
Sep 02, 2017 | Cars & Trucks
Short draining the battery, removed the 5 amp fuse for backup, solved the problem with the short but no radio or clock memory and no Radio volume. Where could my problem be?
Try eliminating radio from power system by removing fuse behind radio or positive supple to radio. Replace backup fuse and check if drain still happens. If so, your radio may have internal power short and needs to be replaced.If not, shorts maybe along the the supply lines after the fuse.
Dec 29, 2016 | Cars & Trucks
Hi, I am Indra,, I have a LG Studioworks 563A monitor,, always time is ok,, but evening time is some disturb me,, this monitor evening time voltage capability fault with UPS,, when i start my computer, UPS...
Not sure I fully understand the question but I'll give it a shot. If you mean that your UPS backup shows a fault.. more then likely the problem is with your UPS backup and not your monitor.. (unless your monitor is shorting out or has to much feedback to the power)
A few things that can cause this is a BAD UPS battery or a underrated UPS backup for devices. Based on the information you gave this monitor is a OLD CRT type monitor which uses quite a bit of power. I would first try the UPS backup with other devices to see if the same problem happens just like a computer or any other electrical device with out the LG connected. If the same problem occurs replace the battery and/or UPS backup, if it doesn't ... then you might have to just replace the monitor as it might be shorting out. With out proper test equipment a definite answer might be hard to come by.
Nov 05, 2013 | Computers & Internet
HoursTracker Lite crashes shortly after opening
Same here. I reinstalled once and restored from backup, but now it's the same again.
Apr 18, 2011 | Carlos Ribas HoursTracker Lite - Timesheet
Hello I have a 1994 Honda GL1500 Goldwing. The 5 amp fuse for backup blows every time I install a new one. The backup fuse holds memory for the cb, the radio, the clock. The backup fuse is located on...
I agree it could be the radio. try unplugging the radio then install a new fuse. If the fuse doesn't blow then you've found the problem. If the fuse blows then try unplugging 1 component at a time until the fuse no longer blows. Don't plug in the components after you've unplugged them until you find the issue. The problem with the clock could be related to the direct short - then again maybe not, but finding the short first should be your main priority. If you have any relays associated with those components then that could also cause your problem as the relay may have the short occurring inside.
Good luck!!
Nov 25, 2010 | Honda GL 1500 SE Gold Wing Motorcycles
Short backup time
Suspect battery failure/faulty cell in a batt
Remove batts and check outside unit
charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
faulty one will be obvious.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Jul 06, 2010 | Powerware 9120 UPS System
2005 titan backup alarm guit not beeping at all in cab
the rear sonra light say on all the time.but no buzzer sound. the buzzer is most lickly shorted.
Jun 24, 2009 | 2005 Nissan Titan
Electronics - Others Logo
118 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
