Question about Whirlpool RCC3024 Electric Cooktop
Rf362lxsb hot surface light on - Whirlpool RCC3024 Electric Cooktop
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
Cooktop red light is staying on
The red light is on as a safety to let you know the surface is hot. When the light goes out the surface will be safe to touch with out getting a bad burn.
Please rate 4 thumbs for the free answer.
Mar 16, 2010 | Whirlpool Cooktops
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Just installed an electric cooktop and the Hot Surface indicator light has been on since installation. How do we fix this?
Sounds like a thermal switch which controls the hot surface light is stuck closed.
Charlie
Aug 20, 2009 | Whirlpool Cooktops
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Sep 06, 2008 | KitchenAid 30 in. KECC506R Electric...
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Whirlpool RCC3024 Electric Cooktop Logo
73 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
