Question about Dmm Vision Fitness T9500 Treadmill
Error message E5 T9520 treadmill how to fix - Dmm Vision Fitness T9500 Treadmill
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
E5 message on my Singer Brilliance sewing machine. What does it mean and how do I fix it? There is nothing in the manual to help.
If you are winding the bobbin in the middle of sewing process, it is normal to get a notification (E5) that bobbin winder should be returned to the left position before continuing to embroider.
Mar 21, 2014 | Sewing Machines
How do I fix E5 error on my Vision Fitness T9450 treadmiill
The primary cause of E5 is the elevation system malfunction - Elevation error (signal lost)
First check all wires from the elevation motor to the lower motor control board. Also check the main wiring harness from the console to the lower motor controller to determine if a wire has been cut, pinched or shorted to ground.
If all wiring is in perfect condition and the unit has not been recently moved, dismantled/reassembled, then there might be a failure of the lift motor itself, or in some cases the motor control board (controller)
Nov 26, 2013 | Vision Fitness Exercise & Fitness
Accuchek error code e5
excessive current. At this time the treadmill will start its self-protecting system. Adjust the machine and restart. Overload protecting the motor. Test the motor y/o control board see my personal TIPS for motor help.
Jun 11, 2013 | Exercise & Fitness
E5 senson message appears after I starp up my True 450 treadmill
see this causes and remedy, and fix it. God bless you
However RUN the software calibration for diagnostic, troubleshooting.
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Oct 11, 2012 | Exercise & Fitness
How do I fix an E5 error message on an Ironman 2300.1 treadmill? What does this error message mean? How do I get a manual for this treadmill?
go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
E5 means a key stuck ,some Upper PCA has been failled.
Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 30, 2012 | Ironman Exercise & Fitness
E5 error code on a YorkFitness Inspiration treadmill, anyone know what i should do?
key permanently stuck, remove the keypad connector cable. Restart the power up sequence, if the error disapear the keypad is the cause.
otherwise the PCA is the cause. the chip PCA must be changed.
God bless you
Jun 17, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
Nautilus tc5000 treadclimber has e5 error. Will run for 5 seconds, then stops. Thanks
The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the machine per the instructions in your manual to clear this error code.
Apr 25, 2011 | Sport & Outdoor - Others
Dmm Vision Fitness T9500 Treadmill Logo
49 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Sportsmith LLC
Sportsmith LLC
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
