Question about Sony Ericsson Txt Pro
Can't access contact list
Contact list won't open, nor text messaging
How to block text messages
You can block text messages from a specific number or contact on your Android device with a third-party solution. Just follow these steps.
Blocking Text Messages
Option 1
Note: These steps are for the stock “Messaging” app included with Android 5. Some carriers may include a different app for messaging.
Open “Messaging“.
Press the “Menu” Menu icon icon located at the upper-right corner.
Select “Blacklist“.
Set “Blacklist” to “On“, then select the plus (+) to add a person to block.
Type the number you wsih to block. Check “Block incoming calls” and/or “Block incoming messages” as desired, then select “OK“.
If you wish to remove a number from Blacklist, select the number, then choose “Delete“.
Option 2
If your messaging app does not offer a Blacklist option, use Handcent.
Download and install Handcent SMS for your text messaging needs. It’s available in the Google Play store.
Since you’ll be using Handcent for text messaging, disable the notifications for your current text messaging app. Otherwise, you’ll get double notifications for text messages.
Open Handcent then select the “Menu” Android menu button icon at the upper left corner of the screen, then select the gear in the lower left corner of the screen.
Select “Security & privacy” > “Manage blacklist“.
Tap the plus (+) icon to add the phone number you wish to block. You can choose one from your contacts, call logs, or input the number directly.
Now all of the text messages from that person will be blocked and not visible in the Handcent app. You won’t get notifications you’ve received a message from the person either. If you ever want to unblock the person, return to the “Manage blacklist” screen, tap it, then select “Unblacklist“.
Some users have reported that the app “Private Space” works well for them.
Sending an Automatic Reply
If you want to let a person know they have been blocked, you will need to download and install SwiftReply. SwiftReply will allow you to setup an auto reply for specific Contacts.
Ensure the mobile number you wish to block is listed in your Contacts.
Open “SwiftReply” and tap the plus icon (+) to make a new auto-reply.
Type the name you would like to use for the reply and the text you would like to send to the person.
Scroll down and select “Enable User Filter” > “Contacts“.
Tap “Add” and choose the people in your Contacts list that you would like to receive the reply. Tap “Done” when your list is complete.
Tap “Save“, then tap “Off” to turn the auto-reply on.
The specified people will now receive your message automatically and Handcent will block them from your view.
Feb 04, 2016 | Cell Phones
How to open the gprs on globe
Sometimes,GPRS configuration settings automatically pop-up when you insert your sim and powering the phone ON.it will ask you save and confirm as the default.also ask for the code then just enter 1234. it is free of charge on globe now a days.
For a complete listing of compatible MMS & GPRS phone handsets - send Nokia, Sony-Ericsson, Motorola, LG, Verzio, iPhone 3G or Samsung (your handset model) to 2365.
To get your phone's settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
* Enter 1234 when asked for PIN to save settings.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won't be able to use the service if you have zero balance.
Aug 10, 2011 | Cell Phones
How to send a message with LG 350F i just get this new phone and I am lost
Hello Kafshar,
Open the phone and click the Menu button. Note the center keypad above the numerical keys can click up, down, left and right.
Click the center keypad left until you see the "Messaging" option.
Click "New Message."Click "Text Message."
Enter the telephone number of the person (or people) you wish to send the message to. You can also select people from your contact list by clicking "Add" and then clicking "From Contacts." Select the contacts you wish to text by clicking "Mark" and then click "Done" when everyone has been selected.
Click down until you are in the "Text" box. Type in the message you wish to send. Click "Send."
Best Regards
  • 7 Click "Send."
  • Read more: How to Send a Text Message on a Verizon LG Phone ' eHow.com http://www.ehow.com/how_4507209_send-text-message-verizon-lg.html#ixzz1SJrC2aPQ
  • 4 Click "TXT Msg."
  • Read more: How to Send a Text Message on a Verizon LG Phone ' eHow.com http://www.ehow.com/how_4507209_send-text-message-verizon-lg.html#ixzz1SJpjpNht
  • 3 Click "New Msg."
  • 5 Enter the telephone number of the person (or people) you wish to send the message to. You can also select people from your contact list by clicking "Add" and then clicking "From Contacts." Select the contacts you wish to text by clicking "Mark" and then click "Done" when everyone has been selected.
  • 6 Click down until you are in the "Text" box. Type in the message you wish to send.
  • 7 Click "Send."
  • Read more: How to Send a Text Message on a Verizon LG Phone ' eHow.com http://www.ehow.com/how_4507209_send-text-message-verizon-lg.html#ixzz1SJpdc0HK
  • 2 Click the center keypad left until you see the "Messaging" option.
  • 7 Click "Send."
  • Read more: How to Send a Text Message on a Verizon LG Phone ' eHow.com http://www.ehow.com/how_4507209_send-text-message-verizon-lg.html#ixzz1SJpK1pFN
    Jul 17, 2011 | LG GW300 Cell Phone
    Send Msg
    start the message and the hit menu add recipients then hit name you want repeat for each name you want to add
    May 21, 2010 | HTC Touch P3450 Smartphone
    I have a new samsung t749 impact cellphone. How do I delete recent recipients from the texting list without wiping out/rebooting the whole phone to factory settings? There is a garbage can button which...
    try to open your call manager or call log menu. once open, you can see the list of people whom contacted you and whom you contacted, there's a call log list, press it and it will give you a drop down menu, which will filter the people, select sent messages and it will give you the list people whom you texted, from there you can delete them and they will be removed from your recent contacts.
    regards..
    Feb 28, 2010 | Cell Phones
    Deleting text log from a711 samsung phone
    Access menu>messages>(Now from this screen you should see your Inbox, Outbox, Drafts, Saved, Etc. Check to see if you are given 'Options').
    This should allow you to delete all text messages in each category. If you are not given an 'Options' feature then access your Inbox and from your Inbox use your 'Options' feature to delete all clutter.
    Thanks.
    Apr 02, 2009 | Samsung SGH-E720 Cellular Phone
    Sending text messages from phone to computer
    One of the best things to try is to forward the messages to your personal e-mail account. Depending on how your phone contact list is laid out you can create a new contact and have only yourr personal email address as the contact or when you choose who to send your message to it might say new email address and select that.
    Open the message you want to save and then go in to the options menu (should be the same area where you select to reply) and then choose forward to, and then where to send it. It works on the same principal as a normal e-mail.
    Jan 14, 2009 | Motorola Mobility RAZR V3
    Cannot remove number in the sent IM menu of the LG Rumour
    Click on messaging icon from main menu.
    Click send message.
    Instead of clicking text message click on pic/video message.
    then you have 4 options TO: CONTACTS , TO Mobile#, To Email, And finally To Recent lict. Click on recent list and checkmark all the numbers you want deleted then click options bottom right corner then click delete.....
    All finished hope this helps.
    Jan 05, 2009 | LG RUMOR Cellular Phone
    I deleted a contact from my address book, but their name and phone number still appears in my recent text messaging contact list when I send a new text message. Can you please tell me how to delete their...
    It will probably stay until a different contact takes it's place. You can also try adding their name again exactly as it was. After that, edit from your list of contacts by changing the contact name and number to that of directory assistance or other contact.
    Dec 22, 2008 | Cell Phones
    Need complete recent call log and more days for text message storage
    The call listing only shows one caller by design, to help with clutter on the list. It's a little funky, but if you think about scrolling through pages of the same caller just to find that number to the pizza place again, it makes sense.
    If you open Messaging, you can access the settings in the menu there to increase (or set to never delete) text message life.
    Please let me know if you get stuck!
    Sep 13, 2007 | Motorola Mobility RAZR V3
    Sony Ericsson Txt Pro Logo
    56 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Sandeep Shenoy
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
