Question about Brookstone Boogie Board Paperless LCD Writing Tablet
Boogie board won't erase
The boogie board erase bottom doesn't work
Faults
Try to replace your fuel pump relay. If that doesn\'t work, replace the spark plugs. If that doesn\'t work, replace your high tension leads with boogie cords.
May 27, 2013 | 2001 Nissan Almera Tino
Where can I buy my son a boogie board that does not cost a fortune?
Amazon have some good priced boogie boards but before you rush out and buy one try and decide what size your son needs and how often he will use it and let those answers guide you in choosing the right board for him.
Good luck.
http://www.amazon.com/Whamo-Boogieboard-37-Fiberclad-Bodyboard/dp/B005F5F4CY/ref=pd_sim_sbs_sg_8
Feb 28, 2013 | Toys
I want a recommendation for a site that sells beach floats for adults and kids. Thanks
Take a look at the Toy Splash site. They have some reasonably prices floats, inflatables and boogie boards that are good for all ages.
http://www.toysplash.com/Category/Beach
Feb 28, 2013 | Toys
Are body boarding and boogie boarding the same thing?
Yes, they are exactly the same thing. Body boarding has been sometimes called boogie boarding since the invention of the boogie board by an entrepreneur named Tom Morey.
Jan 14, 2013 | Water Sport
The coaster brake on bike doesn't work, when pressing the pedal back, it just rotates and the brakes don't grab. What could the cause be?
Perhaps the torque arm is not attached to the chainstay. The torque are is a metal bar about 3 inches long X 1/2 inch wide, and the chainstay is the tube of the bike frame that runs from the pedals to the rear wheel hub. There is usually a little metal clip that wraps around the chainstay and is attached to the end of the torque arm with a small bolt.
Sep 02, 2012 | Electra Bicycle Company Rockabilly Boogy
Flat tire on zooper boogie - where would I get a replacement inner tube or new wheel, live in Toronto, Ontario
Canadian Tire...you need a 12" bike tire tube. You should find them near the kids bikes.
Jul 22, 2011 | Zooper Boogie Jogger
Where can I find parts for this stroller ?
Hi , I have just found out that Zooper no longer makes the boogie... :0( I'm having the same problem...Good luck with your search....
Apr 13, 2010 | Zooper Boogie Jogger
Zooper boogie 2005 needing rear tires, canopy, seating material
Are you still looking for parts? shipp.daniel@gmail.com
Sep 08, 2009 | Zooper Boogie Jogger
Zooper Boogie User's Manual
There's a safety lock located on the right side of the frame, about 6-8" down from the handle bar. There are also 2 sliding locks, one located on either side of the stroller, on the underside of the frame. One is located just below the safety lock. First pull up on the safety lock, and while keeping the safety lock open, simultaneously slide the other 2 levers up toward you. The stroller will unlock/open and you will be able to fold it.
Dec 24, 2008 | Zooper Boogie Jogger
Brookstone Boogie Board Paperless LCD Writing Tablet Logo
194 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Tom Chichester
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
