Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite 22082101 water in tub
How to remove the wash drum to get to the pump
  • 1028 Answers
SOURCE: kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Posted on Apr 28, 2008
dutchman05
  • 487 Answers
SOURCE: Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Posted on May 01, 2008
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
  • 97 Answers
SOURCE: water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore elite front loader washer:door locked after repair
If you have cleaned the drain pump and checked ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), then you may have to replace the pump.
Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the error code will continue to appear until the pump is replaced.
The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you are having problems with unlocking the washer, there is a manual release you can use to get the door open: http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_ The problem may just be a momentary glitch in programming related to the "F02" error code you are receiving. If there are any error codes present, the washer will not complete a cycle and will shut down. I would recommend double checking the drainage system one more time to ensure there's nothing caught in the pump impeller or any of the drain lines (you may have overlooked something), followed by replacement of the pump if the problem continues. This will hopefully cure any others issues you may be experiencing with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Feb 18, 2010
My kenmore elite has water inside the drum basket
you either have to bail it out our remov e the hose at the pump and carefully drain it into a bucket. it could be you have a bad pump or a kinked drain hose.
May 26, 2012 | Kenmore Elite Washing Machines
Kenmore elite top load washer will not drain and buzzes until unplugged
Hello there:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washing machine washes but does not release the water.
Mar 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washmachine
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Jul 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite washer Locked
remove bottom panel reach up from bottom to lock area pull the small tear shaped release to open door if water still in tub pump may be plugged to clean turn handle on pump to left and pull out trap and clean ..after dipping as much water out as possible
Jun 26, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
